Biotex Posted December 12, 2012 Share Posted December 12, 2012 Thought I'd share the schematics on how to wire up the interior lights when installing the Euramtech Map light A-7180-BC The letters in red correspond to the Euramtech diagram above Link to comment Share on other sites More sharing options...
Keri Posted April 22, 2024 Share Posted April 22, 2024 I just wanted to say thanks for this. When I connected mine the way I thought it should be and it started smoking I decided it would be a good idea to look up the right way to do it and this was clear and precise. Thanks for posting! Link to comment Share on other sites More sharing options...
pizzaman09 Posted April 23, 2024 Share Posted April 23, 2024 11 hours ago, Keri said: I just wanted to say thanks for this. When I connected mine the way I thought it should be and it started smoking I decided it would be a good idea to look up the right way to do it and this was clear and precise. Thanks for posting! If you smoked it, you probably blew the diode. Change the diode with another and all will work correctly. If you don't then when you turn on that light individually it will back feed and run all of the interior lights. It's not a big deal but just something to note. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted April 23, 2024 Share Posted April 23, 2024 16 hours ago, pizzaman09 said: If you smoked it, you probably blew the diode. Change the diode with another and all will work correctly. If you don't then when you turn on that light individually it will back feed and run all of the interior lights. It's not a big deal but just something to note. Yeah, this is likely why my blazer / s10 cargo B-pillas lights both come on when only one is switched. They are wired as a direct connection. Neither light has a back flow protection diode. I'll have to solder each one up in my next round of repairs. Link to comment Share on other sites More sharing options...
