296 vs 760
I assume you mean 297? I've heard they are stronger, not sure how much, but every little bit counts when it comes to U-joints. comanche.gif
I don't think the 760s ever came stock in an XJ, but they are the same size as the 297s, just stronger.
If I remember right, 97+ in everything. Before that, look for ABS on the non-CAD axles. Back to maybe 90 I think. Could be wrong on that one. You can always buy an axle in good shape and then upgrade the shafts/joints later if they turn out to be 260s.
i thought that the 760s came in the rubicons and 297s in every thing els. reason being they didnt want to put the same ole same in the rubie caus it was pos to be bigger n better . least thats what i remember readin
