flint54 Posted November 24, 2012 Share Posted November 24, 2012 It can be done. Novak says it should work fine as is. I say it can be made to work, but it will take some customizing. Their cable shifter is smooth as silk, very well made, and will work out of the box for NP-231. For NP-242 it required some changes. The NP-242 shift sector has five positions and requires a significant arc swing betwen 2-High and 4-Low. With Novak shift lever installed to the T case, that arc translates into a throw distance of 3.20 inches. The Novak cable has a total available throw length of 3.10 inches. Their fixed brackets limit the adjustment range of the cable ends so it is nearly impossible to effectively get the full throw. Here's how to make it work. First, you need to open the slots in the shift gate, both front and back, 1/4 inch each way. Next, the threaded rod at the shifter end of the Novak cable needs to be shortened to 5/8" total threaded length, measured from the nut that remains installed.. This permits the ball fitting adapter to thread down fully and was neccessary to achieve the throw length match. be sure to carefully chase these threads before reinstalling the ball fitting. The outer cable adjustment at the shifter end needs to be set completely forward as shown here. The outer cable adjustment at the T-case lever end needs to be set completely aft as shown here. And when I say completely, I mean one nut has just barely full thread engagement. Now, the change that really made the biggest difference is to shorten the arc length of the Novak shift lever so that the total required throw length (from 2H to 4L) is reduced to just under 3.0 inches. I played with some numbers and came up with requiring a new attach hole that is 1/2" center to center from the original hole. Shown here in layout. And here after drilling. And here as installed. I'm really pleased with how this turned out, and the only thing I might consider doing is to create a longer arm on the OEM shifter where the Novak cable ball fitting attaches. It should also eliminate the need to change the shift gate slots. Link to comment Share on other sites More sharing options...
reece146 Posted November 25, 2012 Share Posted November 25, 2012 Very nice. This is fiddly stuff that most people don't have the patience to get right but it looks like you've nailed it. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 25, 2012 Share Posted November 25, 2012 :agree: You should send this to Novak so they can make appropriate mods (or at least let customers know) for those in the future using the shift cable on a NP242 case. Link to comment Share on other sites More sharing options...
Casper2000 Posted January 8, 2013 Share Posted January 8, 2013 Is the Jeep NP 242 the same shift pattern as the GM NP 242 ? Being 4low is at the top N below and 2WD below that then 4Hi Link to comment Share on other sites More sharing options...
comanche87 Posted January 12, 2013 Share Posted January 12, 2013 Is this a kit u can buy or need to make it? Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 12, 2013 Share Posted January 12, 2013 Novak sells 2 shifter kits, a cable based kit (like on this thread), and a linkage based kit. Link to comment Share on other sites More sharing options...
Dest Posted July 30 Share Posted July 30 Necroing this thread as it's one of the first search results. In my XJ that I swapped a 242 into I didn't have to do most of the above. I believe most of this is due to Novak updating their design. I did lengthen the cutout for the shift gate in the bottom part but not the top, I'm not sure it was necessary. I didn't have to cut the threaded rod or mess with the cable adjustment in the brackets. I adjusted the 2 ends of the cable a bit, but the real trick was moving the shift lever to it reduce the swing needed (Novaks new design has 4 overlapping circles so I didn't have to drill anything). Thanks for this thread for that last bit, now I can get into 4L reliably, or at least for the half dozen times I've tried in my driveway tonight. Link to comment Share on other sites More sharing options...
