Novak Shift Cable On Np-242
It can be done. Novak says it should work fine as is. I say it can be
made to work, but it will take some customizing. Their cable shifter
is smooth as silk, very well made, and will work out of the box for NP-231.
For NP-242 it required some changes. The NP-242 shift sector has five
positions and requires a significant arc swing betwen 2-High and 4-Low.
With Novak shift lever installed to the T case, that arc translates into a throw
distance of 3.20 inches. The Novak cable has a total available throw
length of 3.10 inches. Their fixed brackets limit the adjustment range of
the cable ends so it is nearly impossible to effectively get the full throw.
Here's how to make it work.
First, you need to open the slots in the shift gate, both front and back, 1/4 inch each way.
Next, the threaded rod at the shifter end of the Novak cable needs to be
shortened to 5/8" total threaded length, measured from the nut that remains
installed.. This permits the ball fitting adapter to thread down fully and was
neccessary to achieve the throw length match. be sure to carefully chase these
threads before reinstalling the ball fitting.
The outer cable adjustment at the shifter end needs to be set completely forward as shown here.
The outer cable adjustment at the T-case lever end needs to be set completely aft as shown here.
And when I say completely, I mean one nut has just barely full thread engagement.
Now, the change that really made the biggest difference is to shorten the arc
length of the Novak shift lever so that the total required throw length (from 2H to 4L)
is reduced to just under 3.0 inches. I played with some numbers and came up with
requiring a new attach hole that is 1/2" center to center from the original hole.
Shown here in layout.
And here after drilling.
And here as installed.
I'm really pleased with how this turned out, and the only thing I might consider
doing is to create a longer arm on the OEM shifter where the Novak cable ball
fitting attaches. It should also eliminate the need to change the shift gate slots.
  • 12 years later...
Necroing this thread as it's one of the first search results.
In my XJ that I swapped a 242 into I didn't have to do most of the above. I believe most of this is due to Novak updating their design. I did lengthen the cutout for the shift gate in the bottom part but not the top, I'm not sure it was necessary. I didn't have to cut the threaded rod or mess with the cable adjustment in the brackets. I adjusted the 2 ends of the cable a bit, but the real trick was moving the shift lever to it reduce the swing needed (Novaks new design has 4 overlapping circles so I didn't have to drill anything).
Thanks for this thread for that last bit, now I can get into 4L reliably, or at least for the half dozen times I've tried in my driveway tonight.
