89Comanche4x4 Posted November 20, 2012 Share Posted November 20, 2012 Is there any leaf springs from another truck that will fit a comanche? Link to comment Share on other sites More sharing options...
Pete M Posted November 20, 2012 Share Posted November 20, 2012 what is your end goal? how bad of shape is your main leaf in? Link to comment Share on other sites More sharing options...
xjrev10 Posted November 20, 2012 Share Posted November 20, 2012 To my knowledge the leafs are unique to the MJ. You can mix and match individual leafs off the main leaf however. Using S10 parts is common or Dakota stuff. Link to comment Share on other sites More sharing options...
HellCreek Posted November 20, 2012 Share Posted November 20, 2012 Full size Jeep pick ups, Wagoneers and Cherokees have the same size main leaves. The complete rear springs will also work as well. They are just built for the heavier vehicles. The years that will fit are 1976-91. Although some people believe that the 3/4 to 1 ton Chevy springs will fit, they are 1 inch shorter on the shackle end and will cause the shackles to lean inward toward the axle and probably flip at full droop. Thanks, Tom Link to comment Share on other sites More sharing options...
gogmorgo Posted November 21, 2012 Share Posted November 21, 2012 Just out of curiosity, would there be any negative effects to going an inch longer? Link to comment Share on other sites More sharing options...
89Comanche4x4 Posted November 21, 2012 Author Share Posted November 21, 2012 thats for the info guys, i managed to dig up the only comanche here in a junk yard where i lived and it had full leaf packs. pete m: i snapped it right in half haha Link to comment Share on other sites More sharing options...
