Comanche_Fanatic Posted November 17, 2012 Share Posted November 17, 2012 I'm new to the 2.8 V6 motors. I don't know of this carburetor is stock, it appears to be a weber. There are a few connectors near it and nowhere to hook it up to. If anyone knows please share Link to comment Share on other sites More sharing options...
gogmorgo Posted November 17, 2012 Share Posted November 17, 2012 My experience with GM engines is that they were exclusively using Rochester carbs, but in/around 86 I'm pretty sure they'd switched the 2.8 to injection. I don't know what they'd be selling to AMC or what AMC would do to them after, but I'd expect a 2.8 from the '80's to have some version of the Varajet, if it had a carb at all. I'd say with about 95% confidence that the Weber is not the stock carburetor. I increase that to 99% if you've got vacuum lines or anything else going to it with no place to connect. If I have to guess at a stock carb, I'd say Varajet E2SE. I think was used on US cars after '81, but afaik we never got it in Canada. It's a computer controlled carb, but that's about all I can tell you. Link to comment Share on other sites More sharing options...
Garvin Posted November 17, 2012 Share Posted November 17, 2012 Mine had the Rochester 2SE 2bbl carb on it which looked stock. I don't believe the Jeeps got the E2SE but I could be wrong. There are a TON of vacuum lines that plug into it that gets annoying real fast. Below is a picture of what mine looked like if it helps any. Link to comment Share on other sites More sharing options...
86FUBAR Posted November 17, 2012 Share Posted November 17, 2012 That looks like the Rochester 2SE and yes jeep did have the E2SE as that's unfortunately what I have . Link to comment Share on other sites More sharing options...
jimoshel Posted November 17, 2012 Share Posted November 17, 2012 All 1986 2.8 V6 engines had carbs. The Rochester 2SE for 49 states and Canada. LaLa land had the E2SE carb. The 2.5 were TBI. Link to comment Share on other sites More sharing options...
