Mostly Renix Tps
I have posted up 25 of my write-ups on Cherokee Forum which deal with the Renix Jeep issues. Here is a link and an outline of them.
http://www.cherokeeforum.com/f51/cruiser54s-mostly-renix-tips-153657/
Revised 11-02-2012
* means instructions have been written.
1-Ground refreshing*
2-C101 connector refreshing**
3-Connector and relay/receptacle refreshing*
4-Coil/ICM contacts*
5-Checking sensor grounds*
6-Sensor ground upgrade**
7-CPS testing and adjusting*
8-TPS testing and adjusting*
9-ECU connector refreshing*
10-Trans plug connector refreshing*
11-Throttle body and IAC cleaning*
12-Setting your 4.0 to #1 TDC*
13-Renix Distributor indexing**
14-Restoring throttle butterfly adjustment*
15-Rear main seal diagnosis*
16-Vacuum test for exhaust restriction*
17-HO engine into Renix*
18-Improving the instrument panel ground*
19-Headlight harness installation*
20-4WD shifting tips*
21- Renix EGR valve test*
22- Renix vacuum harnesses**
23- CPS timing advance mod*
24-4.0 Engine date codes*
25-Valve cover mod*
26- Snugging up intake manifold bolts
27- CPS wiring bypass
28- Setting base idle
29- Renix O2 sensor diagnostics
  On 11/6/2012 at 3:27 AM, ParadiseMJ said:
Looks like I'm in for some reading...thanks for the reference material. And easy to read for us oldsters.
You noticed the font size? I'm old, too!!
Or are you talking punctuation and capitalization?
  On 11/6/2012 at 3:33 AM, ftpiercecracker1 said:
Soo. much. INFORMATION!!! :papers: Its a veritable library of Renix troubleshooting ideas.
I put it in a somewhat prioritized order. For instance, if you've never done it, you should do 1 thru 5 for sure.
