flint54 Posted November 1, 2012 Share Posted November 1, 2012 Welcoming your opinions on how sensitive the transfer case is to fluid level. The book calls for 1.4 liters. I put the fluid into my rebuilt, but not yet installed case, and then held it at all angles while manually turning the yoke to wet all the gears. In my haste, I failed to realize that without a DS installed it would leak. I'm going to add fluid to about what I think spilled, but if I wind up 1/10 of a liter off are there any consequences? I'm not fond of the old "fill until it runs out the hole" method because of angle variation. Thoughts? Link to comment Share on other sites More sharing options...
ComancheKid45 Posted November 2, 2012 Share Posted November 2, 2012 Fill it till it runs out of the hole! Hasn't failed myself or many other vehicles ive used this concept on. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted November 2, 2012 Share Posted November 2, 2012 :agree: Link to comment Share on other sites More sharing options...
flint54 Posted November 2, 2012 Author Share Posted November 2, 2012 Copy, thanks. So it's not sensitive to small amount of excess fluid. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted November 2, 2012 Share Posted November 2, 2012 ...and just to be sure...fill it until it runs out the TOP hole. You'll use a lot less fluid that way. Link to comment Share on other sites More sharing options...
mvusse Posted November 2, 2012 Share Posted November 2, 2012 Filling it until it runs out the (top) fill hole is the correct way to do it, I have found listed capacities to not always be very accurate. Same procedure for axles and manual transmission. Link to comment Share on other sites More sharing options...
flint54 Posted November 3, 2012 Author Share Posted November 3, 2012 RE: "Fill it till it runs out of the hole! Hasn't failed myself or many other vehicles ive used this concept on." Yes, as has also worked well for me on countless axles and MT's, but I was reminded of this by the occaisonal "DO NOT OVERFILL" warnings on some devices, and wanted to be certain this was not the case for NP242. Thanks. Link to comment Share on other sites More sharing options...
mountainman Posted November 4, 2012 Share Posted November 4, 2012 The only thing that will happen if you overfill any manual box is that it will huff fluid out the breather to relieve itself. But yeah filling to the top hole is just fine. Link to comment Share on other sites More sharing options...
