Eagle Posted November 18, 2012 Share Posted November 18, 2012 ... and i have two grounds for the fuel pump No, you don't. There are three wires to the fuel tank. The heavy one is power to the fuel pump. the black is ground. The third is for the fuel level sender, which is obviously also inside the fuel tank. Link to comment Share on other sites More sharing options...
kbusch18 Posted November 18, 2012 Author Share Posted November 18, 2012 I put two grounds for it in the bumper myself can anyone tell me is there something wrong with the distributor in this situation could it possible spark initially then stop Link to comment Share on other sites More sharing options...
cruiser54 Posted November 18, 2012 Share Posted November 18, 2012 Unless it has to do with the cap, rotor, or coil wire, no. The sync generator inside the dizzy is for firing the injectors sequentially only. Has no effect on ignition. Link to comment Share on other sites More sharing options...
cz777 Posted November 20, 2012 Share Posted November 20, 2012 i have the earlier one of this tool .....its a must have and easy to use with care http://www.powerprobe.com/pp3.php please don't do some half witt tests which can damage more then help .... Link to comment Share on other sites More sharing options...
kbusch18 Posted January 2, 2013 Author Share Posted January 2, 2013 Map sensor and a shorted out wire Link to comment Share on other sites More sharing options...
