Wtb Small List Of Stuff For 87 And 88 Mj
89MJComanche
I need the following
Speedo Cable for 87 long bed with AW4 auto and 231 case
Black body molding for 88 drivers side door. The lower rubber molding.
2 later model (92 and up to 01) matched pair of manual front XJ doors, complete with mirrors.
2 92-96 insurance quality fenders.
Long bed tank skid
Short bed tank skid
Long bed tank sending unit (no pump needed)
JCR offload rear Bumper with 2" Reciever
Maroon Bench, or Maroon Bench upholstery that has been removed. ( I don't need the seat frame)
96 XJ sport passengers side front door panel, vinyl kind from stripped sport model.
Plastic screw cap clips that hold cover on relay center.
1 1988 chrome headlight bezel in excellent condition.
1 1988 working blower motor.
Spare tire Jack crank handle used to raise/lower spare tire winch.
1 1988 hood release cable assembly from the under hood actuator into th vehicle interior.
1 maroon drivers side kick panel piece by e brake pedal
I believe I still have a passenger front door (actually, all 4 doors) panel from a 96 XJ Sport. Gray, short arm rest, no map pockets, does have speaker grill, vinyl top, carpet bottom. No hole for window crank as it had power windows, but it should be easy to cut a hole if needed.
Will try to remember to double check at the shop tomorrow.
