So let's do this one now. When changing the fuel pump, is it easier to raise the bed? Or just drop the tank? The tank is 3/4 full. Include the reasoning behind your choice. :popcorn:
As sinkrun stated, leave the bed where it is, leave the tank where it is and remove the drive shaft.
Even if you did raise the bed, the tank would go up with it as it attaches to the bed, not to the frame.
With the tank 3/4 full I would either hotwire the pump (unless it is completely dead) and disconnect the fuel line at the filter to pump fuel out of the tank and into a bucket or jerry can, or put the right side wheels up on ramps.
Mea Culpa. I goofed. Just got through replacing a fuel pump on a S10. That's what I was thinking of when I posted this. Forgot how much easier the MJ is than the S10. Sorry about that. :oops:
