cruiser54 Posted August 26, 2012 Share Posted August 26, 2012 I have the valve cover off and the two pipes that look like triangle chimney stacks are off. When I took them off, there's a brass looking gasket but there was also something that appeared to be a gasket between the brass piece and the valve cover. It was hard and crumbled. I had to scrape it off with my screwdriver. What was that and does it need to be replaced? Also, there's already a hole in the tube facing the back. I'll cut the pipe down and clean out the holes already there. I see nothing plastic with a pinhole in it. I guess you didn't read my write-up real closely. It addresses the gasket issue. Forget about them. The plastic orifice you're looking for is at the end of the rear CCV line, and it is what fits snugly into the grommet. Link to comment Share on other sites More sharing options...
Virginia Posted August 26, 2012 Author Share Posted August 26, 2012 YOu're right...totally looked past the gasket statement. I didn't replace them. I'll look again for the pinhole. Got everything else done. Letting it sit for a bit before cranking. Gonna go have a beer. Link to comment Share on other sites More sharing options...
cruiser54 Posted August 26, 2012 Share Posted August 26, 2012 YOu're right...totally looked past the gasket statement. I didn't replace them. I'll look again for the pinhole. Got everything else done. Letting it sit for a bit before cranking. Gonna go have a beer. I like your work ethic. Like mine. Link to comment Share on other sites More sharing options...
Virginia Posted August 26, 2012 Author Share Posted August 26, 2012 YOu're right...totally looked past the gasket statement. I didn't replace them. I'll look again for the pinhole. Got everything else done. Letting it sit for a bit before cranking. Gonna go have a beer. I like your work ethic. Like mine. It's all about priorities. Link to comment Share on other sites More sharing options...
Virginia Posted August 31, 2012 Author Share Posted August 31, 2012 So, the mod posted here seems to have worked. Cut the vent pipes inside the valve cover down about an inch and cleared the little pin hole. Nothing going into my catch can so far. Awesome! Thanks to everyone for your help. Link to comment Share on other sites More sharing options...
cruiser54 Posted August 31, 2012 Share Posted August 31, 2012 So, the mod posted here seems to have worked. Cut the vent pipes inside the valve cover down about an inch and cleared the little pin hole. Nothing going into my catch can so far. Awesome! Thanks to everyone for your help. So go have a beer. Send any contributions to www.cruiserdeservesanIPA.com. Link to comment Share on other sites More sharing options...
Virginia Posted August 31, 2012 Author Share Posted August 31, 2012 So, the mod posted here seems to have worked. Cut the vent pipes inside the valve cover down about an inch and cleared the little pin hole. Nothing going into my catch can so far. Awesome! Thanks to everyone for your help. So go have a beer. Send any contributions to http://www.cruiserdeservesanIPA.com. I had several the day I finished. I'll have several this evening after work to celebrate one more day of no oil in my catch can. This will be a daily celebration. Link to comment Share on other sites More sharing options...
cruiser54 Posted August 31, 2012 Share Posted August 31, 2012 So, the mod posted here seems to have worked. Cut the vent pipes inside the valve cover down about an inch and cleared the little pin hole. Nothing going into my catch can so far. Awesome! Thanks to everyone for your help. So go have a beer. Send any contributions to http://www.cruiserdeservesanIPA.com. I had several the day I finished. I'll have several this evening after work to celebrate one more day of no oil in my catch can. This will be a daily celebration. I love happy endings........... Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 31, 2012 Share Posted August 31, 2012 Cruiser, I would still like to know what's the purpose of cutting off the vent towers. Will the internal flapper valve still work as designed at the same pressures if you do this? Just can't see any reason for doing it..... :dunno: Link to comment Share on other sites More sharing options...
Virginia Posted August 31, 2012 Author Share Posted August 31, 2012 Me too. Link to comment Share on other sites More sharing options...
cruiser54 Posted August 31, 2012 Share Posted August 31, 2012 Cruiser, I would still like to know what's the purpose of cutting off the vent towers. Will the internal flapper valve still work as designed at the same pressures if you do this? Just can't see any reason for doing it..... :dunno: The flutes were so long that they were sucking up the oil from the top of the head because they stuck down so far and had engine vacuum on them. Link to comment Share on other sites More sharing options...
