1bdmj Posted February 22, 2007 Posted February 22, 2007 my brother needs a new gear box and i have a brand new one out of a tj but i was wondering if it would fit his 96 cherokee? thanks robert
jeepthing07 Posted February 22, 2007 Posted February 22, 2007 If it uses 3 bolts to bolt it to the frame there is a good chance it will work. the YJ box used 4 bolts but i think the TJ used 3.
Rokhound Posted February 22, 2007 Posted February 22, 2007 t & t makes somthing for this here is a link hope this helps http://www.tntcustoms.com/webv5/xj4boltsteering.asp
Eagle Posted February 22, 2007 Posted February 22, 2007 XJ, MJ, YJ, ZJ and TJ should all be the same.
carnuck Posted February 23, 2007 Posted February 23, 2007 For an upgrade, get the 4 bolt box from an FSJ or full size '70's GM car. (casting #76 in them) Just make sure you get one with O-ring lines or you'll need a custom PS hose. It comes with an already dropped arm.
