Scored a set of OEM towing mirrors....!
rocketwheels
....just scored a set of OEM towing mirrors...$30 :cheers:
....also was able to re-install the original Comanche bedliner, had to add twice as many screws to secure it to the side, was warped all crazy.
Weird liner, is a drop in, but doesn't wrap up over the bed sides like most I have seen, has a seperate mounting strip for each side that is grooved to hold the liner and screws to the inside lip of the bed rail....
i hate you. :bowdown:
my stock comanche liner covers the sides and uses screws with these screw type pressure plates to pinch it in. i think there are 8 of them. then 3 rivets on the back of the bed to hold the bottom down. does it look like yours was ever cut down?
i hate the ones that bolt on...they look like crap. that's my 2 cents though.
and that's the exact bedliner i have, except mine only has either 6 or 8 holes on the side, and those have a screw going through to a corkscrewed pressure plate thingy so that when you turn them the tighten the bedliner to the inside edge of the truck.
here's a few pics of the bedliner, it is a 3 piece deal....the liner shell and 2 mounting strips that are grooved on the under side to hold the liner shells upper edge. The strips have become brittle and warped, had to add a few extra screws and redrill a few of them.....also picked up what I thing is a Yota roll/light bar fits good on fender humps....more pics in Fotki, follow the links
http://images21.fotki.com/v578/filelSOy ... liner1.jpg
http://images22.fotki.com/v519/file40tR ... liner2.jpg
yep that's a comanche liner alright. it's identical to mine except that mine has the covers over the top of the bedrail built into it. also, mine uses the wierd corkscrews to hold it in place instead.
I'm guessin that someone choppped it down when they put that wierd rollbar thing on it, or it was a different factory option than mine was.
i've got a stock mancheliner, i know cause it says COMANCHE up against the cab,
it wraps over the sides and has screw holes all around the top, and bottomback edge where it was installed origionally on another manche.
i wonder were u got it from ;)
here is part of the window sticker that I found in the paperwork......$3000 for add ons seems a little steep to me ! selling price $8850.00 with these options ,mark up for Spinaker Blue paint $170.00, 5-spd $191.00, 6cyl $595.00, Pwr Steer $290.00, Tinted Glass $49.00, Cigarette Lighter $27.00.....and then $2995 for Accessory Package and $689.75 for Protection package grand total of $12,534 for a strip job mini pickup with a brushguard ,bedliner and a cigarette lighter!!!? Our dealers here in the city of Huntsville, Alabama are known for their outrageous markups !!!
I know finding comanche mirrors will be hard did s10,ranger,toyota stuff come with a universal type factory mirrors?
I'm pretty sure Toyota 1-ton mirrors would bolt up, but the factory doors have nutcerts (sp?) in them, so you'd have to drill 4 holes in each door, and pull off the interior door panel to get nuts back there.
...yes, the ones I picked up are the same as the ones on warriors truck. BUT, I've found the same ones at O'Reilleys aftermarket. Mine did come from the Chrysler/Jeep dealership mounted on a friends truck, but they may not be "OEM". One of the morrors had been replaced, it is smaller and looks different, but the other is larger and does have some part numbers stamped into it...it will require pulling the doorpanels to mount!
