SteveO Posted August 8, 2017 Author Share Posted August 8, 2017 On 8/8/2017 at 2:50 AM, HOrnbrod said: On 8/4/2017 at 4:38 PM, SteveO said: How do you like it? Does it fit ok or did you need to modify anything? Well made and cools my stroker engine well. Beautiful welds on all the seams. I did have to tweak the lower elbow fitting for the tranny coolant line to clear the frame but no biggie. Good to hear. I am doing this mostly as preventative maintenance . Although once I had her running for a small while the radiator was steaming a little on the pass side and looked rotted on the bottom. Bending the lower line is not a big deal. I'm just glad I was able to find a good radiator source here on Comanche club. I agree on the welds, they are a work of art. Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 9, 2017 Share Posted August 9, 2017 I went to their site but could not find the rad by itself, could you post a link? Link to comment Share on other sites More sharing options...
SteveO Posted August 9, 2017 Author Share Posted August 9, 2017 On 8/9/2017 at 12:35 AM, Jeep Driver said: I went to their site but could not find the rad by itself, could you post a link?Here you go. https://ffdynamics.com/products/jeep-cherokee-aluminum-radiator Link to comment Share on other sites More sharing options...
SteveO Posted August 9, 2017 Author Share Posted August 9, 2017 Installed the JCR front frame / steering box brace. Got the engine cleaned up and ready for the water pump etc. finishing up the dash wiring, preparing the new doors for paint along with some other parts. Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 9, 2017 Share Posted August 9, 2017 On 8/9/2017 at 12:54 AM, SteveO said: On 8/9/2017 at 12:35 AM, Jeep Driver said: I went to their site but could not find the rad by itself, could you post a link?Here you go. https://ffdynamics.com/products/jeep-cherokee-aluminum-radiator Thank you. Link to comment Share on other sites More sharing options...
SteveO Posted August 11, 2017 Author Share Posted August 11, 2017 Installed a new waterpump, thermostat , hoses, and radiator. I like how the FF Dynamics Radiator fits. Cleaned up inside the frame rails and sprayed it with Bedliner. Finishing up the front clip and then on to painting the new doors, fenders along with other parts. Link to comment Share on other sites More sharing options...
SteveO Posted August 21, 2017 Author Share Posted August 21, 2017 Radiator is in. Ran her for the first time in almost two weeks. New pump and thermostat and hoses work good. Looking into open cooling to replace the old hoses. Any one have any upgrade for the tight thermostat housing (hoses being tight together) mocked up the front before paint. Link to comment Share on other sites More sharing options...
SteveO Posted September 11, 2017 Author Share Posted September 11, 2017 Scored a used ARB winch bumper for cheap. Installed new transmission shift linkage. Found a power door harness from a 4 door 96' xj. Prepping for the rest of the parts so I can paint them and move on Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 11, 2017 Share Posted September 11, 2017 How did you get your windshield out? Link to comment Share on other sites More sharing options...
SteveO Posted September 12, 2017 Author Share Posted September 12, 2017 Windshield remover tool. The T handle style with wire. Sold at many auto parts stores. It's a little tricky to save a old windshield but mine was already broke when I removed it so it was easy enough. I removed the rear the same way since I was planning on painting the jeep anyhow. Link to comment Share on other sites More sharing options...
SteveO Posted September 13, 2017 Author Share Posted September 13, 2017 She has brakes for the first time in the 5 years I've owned her. Not sure about the Rustys brake line routing . I may move it or tie it somehow. Link to comment Share on other sites More sharing options...
SteveO Posted September 26, 2017 Author Share Posted September 26, 2017 Well, drove her out of the shop under her own power for the first time in over 5 years. Drove it around the yard a few times seems to run and drive smooth. Ready for front and rear windows to be installed tomorrow. Getting there. https://i.imgur.com/H09D8lB.jpg Link to comment Share on other sites More sharing options...
SteveO Posted September 27, 2017 Author Share Posted September 27, 2017 Coming together now with glass installed. I reused the rear window and seal I removed years ago. Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 27, 2017 Share Posted September 27, 2017 Who installed your windshield? I talked with Safelite yesterday for mine and they say it won't fit with the rubber. Link to comment Share on other sites More sharing options...
SteveO Posted September 28, 2017 Author Share Posted September 28, 2017 On 9/27/2017 at 11:42 PM, Jeep Driver said: Who installed your windshield? I talked with Safelite yesterday for mine and they say it won't fit with the rubber. Expand Had a local small company I deal with do it. He has done a few newer ones on Comanches over the years. Many reasons why I deal with the smaller privately owned companies. He also installed the rear free of charge using the 30 year old seal I had for it. I am happy with the result for the two hundred it costs to do it all out the door. Link to comment Share on other sites More sharing options...
SteveO Posted September 29, 2017 Author Share Posted September 29, 2017 Finished painting the remaining parts . And she is on the road! Picked up my plates today. Link to comment Share on other sites More sharing options...
SteveO Posted September 29, 2017 Author Share Posted September 29, 2017 Skipped the bodywork on the tailgate because of the time of year and knowing I will not be driving it in the western New York winter. Sprayed it quick to match but it was originally black. So I heated up and removed the JEEP decals on the tailgate after paint. I like the look. Link to comment Share on other sites More sharing options...
SteveO Posted September 30, 2017 Author Share Posted September 30, 2017 Maiden Voyage! She is road worthy for the first time in long time! Looking forward to the next stages of my build. *drivers side headlight was out. Replaced both so they match for now. Finishing up the interior is next. A lot of things I figured wouldn't work do, including fuel gauge and horn and all gauges except alternator which charges at 14+. Link to comment Share on other sites More sharing options...
SteveO Posted September 30, 2017 Author Share Posted September 30, 2017 Future plans include but not limited to. -warn m8000 -lights of some sort for front and rear -Dirtbound rear bumper, most likely DIY -finish interior -8.8 ford or dana44 rear -decide to build a dana30 or swap -upgrade the steering or oversteer/highsteer -tint, radio, speakers, remote start/keyless entry -long arm front suspension...much smoother ride -maybe a visor if I can find one - Not driving in the salt ridden roads of Western New York. -who knows, it never ends. Just real happy to finally drive her. Link to comment Share on other sites More sharing options...
DesertRat1991 Posted September 30, 2017 Share Posted September 30, 2017 What's the story behind the '92 that gave up it's life for this project? Why not start your build with that truck? More complete and much rarer than the '87, and still looked in pretty good shape. Just curious. Link to comment Share on other sites More sharing options...
SteveO Posted September 30, 2017 Author Share Posted September 30, 2017 On 9/30/2017 at 1:38 PM, DesertRat1991 said: What's the story behind the '92 that gave up it's life for this project? Why not start your build with that truck? More complete and much rarer than the '87, and still looked in pretty good shape. Just curious. Expand I painted the 92' and sold it. Put a flat bed on it. It still lives local. I searched around for parts rather than hack up the rotted 92'. Link to comment Share on other sites More sharing options...
SteveO Posted November 9, 2017 Author Share Posted November 9, 2017 Long overdue update since it's hunting season here in western New York. Warn m8000 installed behind the ARB Bumper. Noticed the ball joints on my $50 Craigslist axle were worn. Upgraded to alloy USA ball joints. While doing that noticed the tie rod and draglink were worn. Track bar is new, but plan to upgrade to adjustable . I installed a new draglink, end, and tie rod with end that is for the 95' grand Cherokee v8 ZJ. Fits great with no issues. Toolbox installed, working on the interior next . I don't have much drive time before the salt drops . Made a new friend locally who is a veteran Comanche Club member. Bought many much needed parts and a 90' sport truck 4.0l HO swapped 4x4 truck off him that is very solid from Florida. Pictures and build of that to follow. Also, my custom plate arrived 👍. and the wimpy old one. Link to comment Share on other sites More sharing options...
SteveO Posted November 12, 2017 Author Share Posted November 12, 2017 Brought a ladder stand out with my Comanche today mid day . I realized as I made a tight trail back how much I missed driving a jeep. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 21, 2017 Share Posted November 21, 2017 On 11/9/2017 at 1:17 AM, SteveO said: Made a new friend locally who is a veteran Comanche Club member. Bought many much needed parts and a 90' sport truck 4.0l HO swapped 4x4 truck off him that is very solid from Florida. Expand Would this new friend possibly have Bob as a first name? Aka as Buffalo Bob? Link to comment Share on other sites More sharing options...
SteveO Posted November 21, 2017 Author Share Posted November 21, 2017 On 11/21/2017 at 4:36 AM, HOrnbrod said: Would this new friend possibly have Bob as a first name? Aka as Buffalo Bob? Expand Yes, great guy that I can learn a lot from on the Comanche . Link to comment Share on other sites More sharing options...
