I was driving home today when my clutch pedal went almost all the way to the floor...Again. The same thing happened around a year ago and I replaced my master cylinder and my high pressure line from the master to the slave. I bled out my slave cylinder and still no luck. Is there something else I should look for this time? With the clutch an inch from the floor it has already disengaged :dunno:
If the pedal arm is slightly bent it will push the master in at an angle that wears them out in a hurry (also makes it hard to bleed!)
