Transmission compatability
Yes, I have the 2.5L engine.
Do you know what model trannys for the 2.8L chevy engine would work?
From what years and makes can I find this tranny in chevys?
Is this 2.8L the same 2.8L used in early 80's XJ/MJ?
The 1984 - 1986 Jeep 2.8L V6 IS a GM 2.8L engine. Any transmission you can find bolted up to a GM 2.8L (or rear-wheel drive 3.1L or 3.4L) engine will bolt up to your Jeep 2.5L engine. The 2.5L was engineered to share the same bell housing-to-block bolt pattern as the GM 2.8L. The only question is whether or not your transfer case will mate up to the transmission.
