SOA question??
For the ones that have done a 8.8 SOA on the MJ. Did you have to buy new springs or were you able to use spacers to get the lift or maybe some springs out of the boneyard off something else?? Will be using RE DB's when we get the funds.
Charles
Did you have to buy new springs or were you able to use spacers to get the lift?
I don't understand what you're asking. :hmm: How much lift are you looking for? Going SOA and then adding a spacer between the leaf and axle is a poor idea. Spring-wrap gets very bad.
