mj.87 Posted June 13, 2012 Share Posted June 13, 2012 I just bought a Chrysler 8.25 axle and have questions about angle. I am learning as I go but I thought I would turn to the club for some help. What is the best way to determine the proper angle of the axle? I would like to do this right the first time and don’t want the pinion angle wrong after I weld the perches on. Any help would be appreciated. Thanks! :help: Link to comment Share on other sites More sharing options...
jimoshel Posted June 13, 2012 Share Posted June 13, 2012 The main thing you want is for the Input, pinion and transmission output shaft lined up. Not necessarily inline, but at the same angle. http://www.hotrodhotline.com/md/html/dr ... monics.php Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 13, 2012 Share Posted June 13, 2012 Link to comment Share on other sites More sharing options...
mvusse Posted June 13, 2012 Share Posted June 13, 2012 Actually, you probably want the pinion to be 2 or so degrees low as it will turn up under load. That way it will be parallel cruising down the highway. Link to comment Share on other sites More sharing options...
mj.87 Posted June 14, 2012 Author Share Posted June 14, 2012 Great help! Thanks! I guess install the new axle without the perches welded on, measure with an inclinometer, mark perch position, uninstall, and then finish the job. Is this correct? Link to comment Share on other sites More sharing options...
Rymanrph Posted June 14, 2012 Share Posted June 14, 2012 I'm putting ACOS on the front of my truck and since the height of the front of the truck determines the angle of the driveline, how do you compensate in the rear if you make height adjustments up front? Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 14, 2012 Share Posted June 14, 2012 I used axle shims (3* IIRC) to set the drive line angle after finishing the lift. Just make sure you use steel, not the cheaper aluminum ones as they will crumble eventually. Link to comment Share on other sites More sharing options...
