HKB3 Posted May 9, 2012 Share Posted May 9, 2012 So I searched and found a few threads about putting a 22 gallon Dakota fuel tank in a Comanche but all were 97-up swaps(which I plan on doing in the future) for right now I still need the use of my truck and my fuel tank is leaking(rust, I pulled it this morning) was thinking of going ahead and install a Dakota tank, how much trouble will it be to adapt it to work in my 1992 2.5L ? Would it be worth the trouble or should I just get a new stock tank? Thanks Link to comment Share on other sites More sharing options...
peteco Posted May 15, 2012 Share Posted May 15, 2012 wouldn't a pick and pull have a tank? anyone know if a cherokee tank works? Link to comment Share on other sites More sharing options...
Eagle Posted May 15, 2012 Share Posted May 15, 2012 wouldn't a pick and pull have a tank? anyone know if a cherokee tank works? I would expect a tank from a pick-n-pull to be full of leaks. Just buy a new MJ tank -- they aren't all that expensive. No, a Cherokee tank won't work. They are completely different. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted May 15, 2012 Share Posted May 15, 2012 where is a good place to get a new replacement tank? Link to comment Share on other sites More sharing options...
HKB3 Posted May 15, 2012 Author Share Posted May 15, 2012 I bought a stock replacement tank from JC Whitney excellent service, received my parts in two days and at a good price. Thanks Link to comment Share on other sites More sharing options...
johnj92131 Posted May 16, 2012 Share Posted May 16, 2012 Here is a link to JCWhitney and Commanche tanks: http://www.jcwhitney.com/replacement-oe ... 169y1991j1 More at JCwhitney: http://www.jcwhitney.com/spectra-fuel-t ... 169y1991j1 Don't forget to check Ebay: Lots of tanks there with prices all over the place. If your 92 is a short bed then you need 18 gal tank. Long bed needs 23.5 gal tank Link to comment Share on other sites More sharing options...
87Warrior Posted May 16, 2012 Share Posted May 16, 2012 The Dakota tank will not work with your existing fuel pump and sender. The MJs fuel pump and sender are side mounted while the Dakota is top mounted. Link to comment Share on other sites More sharing options...
