apexjeepinjoe Posted May 6, 2012 Share Posted May 6, 2012 So the AX15 I bought out of 1998 TJ has a little bit of play in the input shaft is that normal. Also I removed my BA10 and it looks like the previous owner just put a new clutch in. Does anyone know the stock clutch thickness? Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 7, 2012 Share Posted May 7, 2012 Yeah I think there is supposed to be some play in it. The few AX5s I had here had the same play. Link to comment Share on other sites More sharing options...
H8PVMT Posted May 8, 2012 Share Posted May 8, 2012 Mine is sitting on a workbench and there is very little movement Link to comment Share on other sites More sharing options...
Comanche County Posted May 9, 2012 Share Posted May 9, 2012 Pull the bearing retainer off and yank the bearing and inspect it for play. That may be all you need. Link to comment Share on other sites More sharing options...
