2.5L valve cover leak
I think I've tried every gasket and or sealer on my valve cover and it always end up leaking after a few weeks. I don't have any blow by going into the air box and the breathers are all open. Has anybody had better luck with any perticular gasket or silicone gasket maker? It's an 89 MJ, 2.5 plastic valve cover. Doesn't seam to be warped or cracked. Had 180,000 on my last 87 Mj and the valve cover was the only place it ever leaked oil from.
Thanks Glenn
Ditch the plastic valve cover and get one off a 91 and up Wrangler, and the proper rubber gasket....no more leaks. Its not the gasket leaking, its the cover warping.
Hard to find......been looking.
The cover is warping that why I use a liberal amount of UB the snug the bolts down just until the UB begins to ooze.
