AMCJeepMJ Posted March 16, 2012 Posted March 16, 2012 Hi all, As it was precipitating a rain/snow mix this morning on the way to work which required use of the wipers, I had noticed the speed of the wiper blades/arms [on my 87] when set to Intermittent was faster to sweep across the window than the Slow constant wiping speed, and nearly as fast as the Fast constant wiping speed. This is not in reference to the adjustable delay of the Intermittent setting, but the speed at which a single swipe, up and down, of the window is completed. Is this something that you have observed as well?
MJRemi Posted March 16, 2012 Posted March 16, 2012 I have not experienced that but it sounds like it is column switch related since the intermittent relay seems to be fine.
carnuck Posted March 17, 2012 Posted March 17, 2012 normal as mine was (I hope see it in action again by the end of the weekend)
