Pete M Posted March 9, 2012 Share Posted March 9, 2012 if you push the gas pedal too fast, the engine gasps and tries to stall. if you push slowly, it works ok. does the same in gear as in neutral. idles fine. sounds fine. started doing this right outta the blue. thoughts? :dunno: edit: took it for a spin and now it'll be fine, then bad, then fine, then bad. I think a fuel filter change is in my near future. can't hurt, right? Link to comment Share on other sites More sharing options...
ejndssn Posted March 10, 2012 Share Posted March 10, 2012 have you run injector cleaner through the system :idea: i would start there since it quick and easy the next area is this vehicle EGR equipped if so then that would be the next place to check just a thought Link to comment Share on other sites More sharing options...
carnuck Posted March 10, 2012 Share Posted March 10, 2012 TPS could be going out or a patch of water in the fuel. Link to comment Share on other sites More sharing options...
Pete M Posted March 13, 2012 Author Share Posted March 13, 2012 went to the junkyard and picked up a couple TPS's, an EGR and a MAF and it turned out the MAF was the problem. :wrench: (out of about 12 cars, only one still had a MAF in it) Link to comment Share on other sites More sharing options...
