MancheKid86 Posted March 2, 2012 Posted March 2, 2012 how do you remove them? I'm having troubles getting them out, i have the re-placement ones that came with my swaybar links from zone offroad, i just can't get the old ones off XD
Abyx Posted March 2, 2012 Posted March 2, 2012 They're splined in. Use some kind of applicable force to remove them, either a press, a hammer, an air hammer or a hammer.
xjrev10 Posted March 2, 2012 Posted March 2, 2012 Yep, press fit from the factory. Little heat and a hammer should do the trick.
SW86 Posted March 3, 2012 Posted March 3, 2012 BFH (big @#$%ing hammer) is all you need. i don't really remember doing mine but I'm pretty sure a hammer was used.
johnnyc Posted March 3, 2012 Posted March 3, 2012 When I did mine many years ago, I tried heat and BFH. No go. But an air chisel got them off in seconds. Just put the the chisel under the bolt head.
