drcomanche Posted February 14, 2012 Share Posted February 14, 2012 So, as it turns out, I will be getting a pretty decent amount back on my taxes, and we all know what that means... MORE PARTS! :cheers: This will give me the opportunity to purchase some parts that I wouldn't have been able to get before now. So my question to the knowledgable people of ComancheClub is what do you guys think I should get for the truck? I've looked over a couple of things already, and some parts that are being considered are: A TnT truss with brackets to sort out the mess that is my front axle and give it a bit more strength. This would help with my steering problems and my on road vibrations, and could give me a chance to rebuild that front axle, change all the bushings and whatnot. The issue I have with this is that my experience with welding is nonexistent, and I don't want to mess up the axle, so I may have to get it professionally done. The other problem is that this is my only vehicle, and my daily driver. A new bunch of Interco Iroks. My front tires are looking a little worse for the wear, so obviously that's the benefit there. A rear locker for the 9. It already has a spool, but that thing is absolutely destroying my tires and gas milage, and being able to turn does help a lot(plus, it will keep me from fishtailing in the roundabouts). So, anything you guys suggest? Any opinion on what I have already? Link to comment Share on other sites More sharing options...
89eliminator Posted February 14, 2012 Share Posted February 14, 2012 based of your list, my order would be: truss tires locker Link to comment Share on other sites More sharing options...
XxStirCrazedxX Posted February 14, 2012 Share Posted February 14, 2012 Is it a stock 30? If so just pick up a used one from cl and build it. Less down time on your dd. Just my 2 cents. Link to comment Share on other sites More sharing options...
XxStirCrazedxX Posted February 14, 2012 Share Posted February 14, 2012 Nevermind...just seen your Sig Link to comment Share on other sites More sharing options...
