My Badass Metric-Ton Comanche Build! (The End)
Looks to me like it's the RE1660 tracbar. If it is, it's upside down and is missing the required RE1665 bracket.
it is not
I'm looking really hard, and I see no heim on the frame end. just a welded piece with a rubber bushing.
cam I'm not an idiot,
may not be a heim,
BUT, I WAS CORRECT.
it is a rear zj track bar,
I'm not @#$% stupid.
http://fatbobsgarage.com/i-6785322-jeep ... ation.html
so where is this rubber bushing you see on my frame?
took closer pics so you can stare at it longer if you would like
still think its backwards?
didnt think so.
It's worse than backwards, because it's a ZJ rear trackbar ON THE FRONT OF AN MJ!!!!
  • Replies 124
I'm okay with it,
ill ride it and if it give me ANY grief,
i will replace it.
hmm seems ive came a bit unglued earlier,
last little while has been a little rough,
havent had a real day off or rest for the last 7 months,
11 more to go o_O
started on my rear axle today,
shafts were not going in,
and NO i did not put them in backwards, ive swapped them multiple times to make sure.
cracked the lid, pulled the carrier found the culprit.
cover off
carrier unbolted
carrier out
you can physically see its not going in all the way :ack:
damm 2 part spiders are mis-aligned
more to come
it is not
may not be a heim,
BUT, I WAS CORRECT.
didnt think so.
Never said you were an idiot, and I'm not trying to make you feel bad. Just looking out for a fellow jeeper. :wrench:
And I will say you upgraded from your last truck. looks good, keep it up :thumbsup:
thank you sir!
just had an over the top day :oops:
so i got more work done on the beast.
fixed my locker.
i know this isnt the recommended way, but needed to get them started,
realized they are a reverse thread,, figured that after i couldnt turn them any more.
all dis-assembled for inspection,
its a 2 piece gear system,with an interference fit,
so when the guy at truck works assembled it he didnt watch to make sure they stayed in place.
making the bolts nice and snug with the axle shafts in the locker to KEEP IT aligned XD
a bit of extra grease to compensate for the grease that was absorbed into my hands :P
back in her spot
all bolted up and ready to go :D
rtv'd the cover, not fully bolted down, just enough for the rtv to come out the seam,
once its set up will snug it up
more to come like always,
need to install the new brake cylinders and then this bad boy is going into the jeep
:banana:
off with the old
on with the older!
my 1974 cj pilot bushing for my 1999 ax-15
clutch off, will last a lil bit longer, still has most the "friction" grooves
the damned flywheel it self, can't get the pilot bushing out, gone through lots of grease,
pilot bushing puller is discontinued from my parts store.
removing my slave cyl fitting for reference,
15.49 online +$123 shipping? i don't think so...
old vs new brake cyls
old vs new hardware
axle now complete
spring perches on,
pinion angle of 10 degrees,
and welded on the inside too
once i get that damn pilot bushing out, i will get that transmission in,
once i get that, then i can get my drive shaft shortened+installed
mount shocks, run brakes,
front uca bushings,
not much progess,
last couple days ive tried getting the damn pilot bearing out
FINALLY GOT IT OUT
tried everything
even rented a pilot bearing puller
went through an entire tub of grease :rotf:
pilot bearing remover,
(yes the other claw is attached :P)
didnt work
shure showed it :shake:
who buys a battery for 3 slices of pizza, lol. it looks like you have some good things on the go - i will be following with interest. great lookin truck btw.
ps. do you happen to know the height of the front springs? I'm interested for reference.
transmission seems more of a pain getting in without a jack than i thought :rotf:
need to get the proper one,
got my build sheet from btm24,
thanks again! :D
VIN: 1JTMW66T8JT030091
Model Year 1988
Family MJ - COMANCHE
Engine ERB - ENGINE - 4.0L I6 MPI GAS
Transmission DDJ - 5SPD MANUAL TRANS A881 (JA-41)
Market C - CANADA
Body Model TP62 - No Description Available
Build Date 08/27/87
Trim *W7 - Cloth Lo-Back Bckt/Red Accent Seats
Trim Color -SA - Charcoal
Tire -
*W7 Cloth Lo-Back Bckt/Red Accent Seats
-SA Charcoal
ADA LIGHT PACKAGE
ADB PROTECTION GROUP PACKAGE
ADE COLD WEATHER GROUP
AGL Super Sport Group (SS/T)
APA MONOTONE PAINT PACKAGE
AWJ Visibility Group
BCQ Battery - 750 Amp Maintenance Free
CAC BUCKET SEAT - LO BK
CGW Air Bags - Front, Next Generation**
CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ
CUF FULL LENGTH FRONT CONSOLE
DDJ 5SPD MANUAL TRANS A881 (JA-41)
DSA LIMITED SLIP DIFFERENTIAL
DTA
ERB ENGINE - 4.0L I6 MPI GAS
GAC ALL WINDOWS - TINTED GLASS
GFD SLIDING RR WINDOW
GTZ MIRRORS - MANUAL REMOTE
JDA SPEEDOMETER - 140 KILO PRIMARY
JFH TACHOMETER - MECH
JGB Clock - Digital
JJA CIGAR LIGHTER - FRT COMP
K60 BODY SIDE MOLDINGS - VINYL
KQJ
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LDA UNDERHOOD COMPT LAMP
LMA HALOGEN HEADLAMPS
LPE EXTERIOR CARGO LIGHT
MBF REAR BUMPER - STEP TYPE (BRIGHT)
MCA FRONT BUMPER GUARDS
MCB REAR BUMPER GUARDS
MDA FRT LICENSE PLATE ATTACH REQUIRED
MFD BRIGHT GRILLE - TYPE I
NAG
NFA TANK - 20 GAL FUEL
NHM AUTO SPEED CONTROL
PWB
QWB
RAF Radio - AM/FM Cassette
SBA POWER STEERING
SCG LEATHER STRG WHEEL - EURO/SPORT TYPE
SUA TILT STEERING COLUMN
TBB CONVENTIONAL SPARE TIRE
WJN 15" Aluminum Wheels
pre-pressurized clutch line came in the mail yesterday :D
gotta love rock auto
my transmission x-member gave me lots of trouble,
turns out the other mounting holes were covered in rust paint and undercoating
installed my x-member and the nuts were rotted enough for the threads to give out,
out comes the tap + heli coils
finally transmission is supported by its own,
no more jack
next project
out with the old
in with the dana-44 rebuilt, re-sealed and with a pozi :banana:
would have it strapped in and tires on,
but the u-bolts that were on the 35 are too short,
and all the parts stores close at 5 on sundays :(
got some u-bolts bent up at truck works today,
same place my axle was built before i owned the truck (which i had to re-do XD )
turns out they made them a little too small,
i "made" them go on
axle swap complete
e-brake cable's installed
as far as i have gotten with my master cyl,
have to drill some holes in the fire wall
look!
a stock vanity mirror,
i laughed my @$$ off when i seen it, any one else have one?
i think I'm doing good on this truck,
ive done alot of things ive never have done before,
first axle swap,
first 4wd conversion
more to come!!
axle shaft is getting shortened this week :jump:
look!
first axle swap,
more to come!!
Looms good! My dads 86 xj has one of those mirrors...
It's good for the ladies ;) :brows:
I agree you have some sweet progress going on here keep it up! I had a lot of firsts with my truck too! Axle swaps, engine pulling, lifting haha pretty much everything
Good truck to learn on!! 8)
Thats one nice rig! Wish mine had some of the accessories yours came with factory! Must be nice to have a factory cargo light! I will be putting mine on this weekend.
I too will be looking to swap in an ax15 and a 242.
Good luck, keep the pics comin!
Gary
finally got that damned bushing out,
glad i only had to replace the one ( was missing the sleeve inside)
i mentioned machine shop to my step father and he said he could get it out.
well he was right, its out :rotfl2:
empty hole
new bushing (have 3 spares XD)
then i beat the new bushing in,
used 18" of 3/8 extensions went right in after 15 mins with the BFH
all bolted up
truck supports itself again :yes:
getting closer every day,
to do list:
install front drive shaft
run rear brake lines
shorten rear drive shaft
tape measure alignment
get a new cps
drill holes in firewall for new master cyl
get stock air box or get 'warm air intake"
and get new pcv valve (sat on it while trying to undo the top torx e-12 bolts)
i can't wait to be able to drive a comanche again there is NOTHING like it jamminz.gif
well got my master+slave cyl installed,
i got the pre pressurized package,
ROCK SOLID, never had clutch feel like this before,
our bmw and 2005 jeep wrangler unlimited doesnt even compare.
great investment jamminz.gif just had to drill 2 holes and after that it was bolt on :D
front axle shaft installed,
with the 4.5" lift the slip yolk only moved 1/4" roughly compared to stock
drive shaft getting dropped off tomorrow to get shortened,
got my new drive shaft installed today :yes:
even got some spicer u-joint
and new cps
IT LIVES!
all i gotta do now, is mount shocks (gotta fab mounts up still)
and run brake lines,
alignment
took the beast for a spin today,
sure as hell need those rear shocks + brake lines,
also need a 4wd shifter,
sucks shifting it into 4wd from under the truck
got er stuck for the first time today in my neighbors driveway,
first run out :rotf:
more progress,
took the truck for a spin, see proof it moves!
its in its spot the other way around
shocks mounted on the frame,
neighbor will weld my brackets on later this week,
wednesday or thursday :( id like it to be sooner, but
his welder his dime.
brake lines all mocked up for tomorrow! i get my extended rear line made up at truck works
will have full brake power,
yes i know, the line over the pumpkin is hideous,
but hey it gets the job done, i could have re-flared the line shorter but didnt see the reason to chop a perfectly good flare off
more to come!
got my brake line made up today,
well i really under estimated, so i had to route the line a bit different, lots of play now,
also my line doesnt look so hideous any more i still need to tweak it a bit to fit the axle but it turned out decent
also installed the front bumper gaurd XD
need to get around to swaping my other 97+ mirror on,
get the shock mounts welded on in the next day or two
