88 mj not charging. please help
Does the gauge show voltage? or is the idiot light on with key on not running?
If not you found your problem, take a test light and touch to the non yellow wire and see if it lights up.
If it does have someone start the truck and see if the test light goes out, if it doesn't then you have a wiring issue to the dash.
