Blue88Comanche Posted January 16, 2012 Share Posted January 16, 2012 I swapped in a D44 this weekend. and it looks like my slip yoke has very little play... The D44 is about a inch longer than the D35.. do i need to get my drive shaft shortened right now or is it something that can wait as long as i just use it to go around town in? Thanks Link to comment Share on other sites More sharing options...
COMANCHEROB4WD Posted January 16, 2012 Share Posted January 16, 2012 If its tight I wouldn’t drive it. It can break the tailshaft. It will def need shortened. After confirming this with guys here at work, and remembering that it's a common problem on XJ's and YJ's as well, again, I would shorten it before you drive around so you don't cause any damage. Link to comment Share on other sites More sharing options...
mvusse Posted January 16, 2012 Share Posted January 16, 2012 Get it shortened now or put the 35 back in until you do. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 16, 2012 Author Share Posted January 16, 2012 I won't drive MJ any this week so i guess i will go ahead a remove the shaft tonight or tomorrow. how much should i get it shortened? and about how much does it usually cost to get it shortened VS getting a new one? Link to comment Share on other sites More sharing options...
Boots Posted January 17, 2012 Share Posted January 17, 2012 I used my stock shaft after I swapped in my Dana 44 for almost a year. I had it off road a couple times and launched it off the top of a sand dune once, didn't hurt any thing. But yours sounds like it might be a little tighter of a fit... Better safe than sorry. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 17, 2012 Share Posted January 17, 2012 I won't drive MJ any this week so i guess i will go ahead a remove the shaft tonight or tomorrow. how much should i get it shortened? and about how much does it usually cost to get it shortened VS getting a new one? When I swapped the D44 in I had the shaft shortened 1" then balanced, blasted & painted, cost me $70 up here in Huntsville. :cheers: Link to comment Share on other sites More sharing options...
cody4359 Posted January 17, 2012 Share Posted January 17, 2012 lift your truck more, problem solved :wrench: Link to comment Share on other sites More sharing options...
mvusse Posted January 17, 2012 Share Posted January 17, 2012 And for the question about shortening the original or getting a whole new shaft, having the original shortened is cheaper because all you pay for is labor. You already have the tube and both ends. Having a new one built you pay for the tube, the yokes AND the labor. Will probably double the cost. But if you have a new one made, it can be made to your specs. Mine is made from .3" diameter, .188 wall DOM tubing. Expensive as all heck (the tube alone was over $100), but after I was sitting on the shaft rolling side to side instead of moving forwards or backwards it is still straight without any dents. Wish I would have gone that route the first time before I turned my stock shaft into a candy cane, bent and dented a shortened 2wd Toyota one (looks some someone went to town with a sledge) and twisted another stock one in half. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted January 17, 2012 Author Share Posted January 17, 2012 called the local off-road shop, $125 to shorten blast and paint.. so tonight looks like i will be removing the shaft and taking it in tomorrow. Link to comment Share on other sites More sharing options...
