The deal is I have a 88 mj 4.0 auto trans PO beat the piss out of it so far I've replaced one pushrod,timing chain&gears,vacuum lines,etc. Took apart head and replaced a bent pushrod,brand new gaskets on the thing,all vaccuum hoses have been replaced within the last 3 months,all injectors are firing,after installing new pushrod it still acts the same. Also replaced fuel filter&pump.
Currently rebuilding another motor for it out of a 94.
Any ideas?? thanks in advance
According to my limited mechanical knowledge, en engine backfires when an intake valve is open at the same time the spark plug is firing. I would look at either the valve timing or the ignition timing -- or both. Or, if you changed the plug wires, check the firing order.
-Tom
If it's backfiring, it is virtually 100 percent certain that the timing can't be good. Check it again. Be sure #1 is at top dead center ON THE COMPRESSION STROKE, then check the distributor to see if the rotor is pointing at the #1 terminal in the cap.
