EGR Valve
Here's a useful link to some of the equipment involved on the Renix motors. http://www.lunghd.com/Tech_Articles/Eng ... ostics.htm
Your issue could be a few different things so test and research a bit more before buying a new EGR valve and if you do buy one, it shouldn't be anywhere near $100. More like 1/2 that. Rockauto has the Delphi on closeout for $25 + SH. (you'll need a gasket also)
Are there emission restrictions in TX that force you to have a working EGR? I fiddled and futzed with mine for quite a while and it seemed the only solution was to buy a new one (which are pricey). I wound up capping off the vacuum line going to it and the truck ran great and still passed NJ emissions.
TESTING THE EGR VALVE FOR 87-90 4.0 ENGINE
Valve Opening Test
1) With engine at normal operating temperature and at idle,
rapidly open and close throttle. Open throttle sufficiently to obtain
at least 1500 RPM. Movement should be noticed in EGR diaphragm.
2) If diaphragm does not move, probable causes are: faulty
vacuum signal to EGR, defective EGR diaphragm or defective
backpressure sensor diaphragm (if equipped), or leaks in vacuum lines
or connections.
Valve Closing Test
manually depress EGR valve diaphragm. RPM should immediately drop,
indicating that EGR valve is not leaking and had been properly cutting
off exhaust gas flow at idle.
2) If there is no change in RPM and engine is idling
properly, exhaust gases are not reaching combustion chamber. Check for
plugged passage between EGR valve and intake manifold.
3) If engine idles poorly and RPM is not greatly affected by
manually moving diaphragm up, EGR valve is not closing off exhaust gas
flow. Check for carbon between pintle, leaking EGR valve gasket or bad
EGR valve.
