64chevy
Everything posted by 64chevy
  1. Will the 15" Jeep Grizzly wheel fit on a 1989 Comanche?
  2. It was a bad EGR valve. Thank you for the help!
  3. It was a bad EGR valve. Thank you for your help!
  4. I'm looking for a replacement throttle linkage for a 1989 Comanche 4.0l. Any suggestions? Thank you!
  5. We cleaned the EGR valve and it appears to be working but we stall out during deceleration. Do I spend $100 on a part that appears to be working? Any suggestions? Thank you!
  6. We have cleaned the throttle body and have done the following: crank sensor, stator, idle air control motor, oxygen sensor, EGR solenoid (we cleaned the EGR valve), ignition wires, plugs, distributor cap and rotor and fuel filter. In addition I've replaced the muffler, heater core, blower, resistor, oil pan gasket, rear main seal, PVC assembly, vacuum harness and battery. Do you think an EGR valve can appear to work but not actually be working... Needing to be replaced?
  7. My 1989 Comanche SporTruck 2 WD 4.0L / automatic starts easy, runs smooth but sputters and sometimes stalls on deceleration. Any ideas would be greatly appreciated!!
  8. How do I check and clean the IAC & EGR on a 1989 4.0?
  9. I'm having trouble keeping my 1989 MJ running at idle. I have changed almost all of the emission vacuum harnesses, new plugs, rotor, cap, wires, fuel filter, O2 sensor... Give it fuel and it runs fine... Any suggestions?? Thanks!
  10. 64chevy
    Part Suppliers
    What is the best source for MJ parts?
  11. I'm restoring my Dad's 1989 Jeep Comanche Sportruck with the 4.0. Any advice on emissions? The truck was exempt from safety inspection emission testing in Oklahoma but must pass in Texas. The emission dash light is on. Also, any good OEM part suppliers? Thanks for your help!!
