I actually found a good set @ the junkyard :eek: To remove use a piece of 1x2. But it up to the metal trim piece and GENTLY tap it as straight up as you can, WITH THE WINDOW DOWN!!! Once off, use yer favorite flat screwdriver to open the clips just enough to take the window sweep out. While they're out give the trim a coat of flat black, instalation is reverse.
25 bux don't seem bad to me cause I've bought the ones for a 96 Dodge Ram before :ack:
i need the outer lower trim peice for my driver window i can get it 4 25 bux at the dealer but i want to no if ne one has messed wit there b4
Mate, your post took me three times longer to read than if you had written it in standard English. This is an Internet forum, not a cell phone with a character limit on text messages. Please do yourself a favour and quit using text message shorthand where it isn't needed or wanted. It makes life SOOOOO much easier.
Thank you.
Thank you.
:yes:
