koooooooz Posted January 24, 2007 Posted January 24, 2007 i need the outer lower trim peice for my driver window i can get it 4 25 bux at the dealer but i want to no if ne one has messed wit there b4
jbhill Posted January 24, 2007 Posted January 24, 2007 the belt moulding? I'm assuiming your talking about the black rubber piece along the bottom of the window frame?
BIGMASS Posted January 25, 2007 Posted January 25, 2007 I actually found a good set @ the junkyard :eek: To remove use a piece of 1x2. But it up to the metal trim piece and GENTLY tap it as straight up as you can, WITH THE WINDOW DOWN!!! Once off, use yer favorite flat screwdriver to open the clips just enough to take the window sweep out. While they're out give the trim a coat of flat black, instalation is reverse. 25 bux don't seem bad to me cause I've bought the ones for a 96 Dodge Ram before :ack:
Eagle Posted January 25, 2007 Posted January 25, 2007 i need the outer lower trim peice for my driver window i can get it 4 25 bux at the dealer but i want to no if ne one has messed wit there b4 Mate, your post took me three times longer to read than if you had written it in standard English. This is an Internet forum, not a cell phone with a character limit on text messages. Please do yourself a favour and quit using text message shorthand where it isn't needed or wanted. It makes life SOOOOO much easier. Thank you.
feerocknok Posted January 25, 2007 Posted January 25, 2007 i need the outer lower trim peice for my driver window i can get it 4 25 bux at the dealer but i want to no if ne one has messed wit there b4 Mate, your post took me three times longer to read than if you had written it in standard English. This is an Internet forum, not a cell phone with a character limit on text messages. Please do yourself a favour and quit using text message shorthand where it isn't needed or wanted. It makes life SOOOOO much easier. Thank you. :yes:
DirtyComanche Posted January 26, 2007 Posted January 26, 2007 That wasn't too bad as far as shorthand goes. Obviously Eagle dun use text messaging.
fiscus Posted January 26, 2007 Posted January 26, 2007 I pulled em all off by hand easily on my door, but I had the inner skin off & the window rolled all the way down.
