thatjeepguy64 Posted December 20, 2011 Share Posted December 20, 2011 i bought a comanche about 2 weeks ago and i just bought a 41/2 lift kit and 4.10 rear that came from a cherokee...my question is could i just throw in that rear and leaf springs from the cherokee or will i have to use the comanche springs..will i have to move the perches from the cherokee rear? Link to comment Share on other sites More sharing options...
86customanche Posted December 20, 2011 Share Posted December 20, 2011 You can use that rear end but you will have to weld on new perches(can resue the cherokee ones) and reuse the comanche springs. They are slightly longer than from the cherokee. As far as the 4.10 aspect goes, unless you have matching gears in the front end you cannot use 4wd with non matching gears. Having a 4.10 rear and say a 3.07 front can be driven but only in 2wd until they are the same ratio. Link to comment Share on other sites More sharing options...
TylerJY Posted December 20, 2011 Share Posted December 20, 2011 You'll have to reuse the MJ leaf springs, but you can weld your perches on top of the axle, and it will net you about 6.5" of lift. Link to comment Share on other sites More sharing options...
thatjeepguy64 Posted December 20, 2011 Author Share Posted December 20, 2011 its a 2.5 with a 4 speed, i should of thrown that out there before...do the comanches have the 4.10s with 2.5 or would it be different with the 4 speed?...and with the cherokee rear the perches are on top. Would i still have to cut those off? Link to comment Share on other sites More sharing options...
86customanche Posted December 20, 2011 Share Posted December 20, 2011 the 2.5l 4 cyl should have 4.10s in it already. Link to comment Share on other sites More sharing options...
thatjeepguy64 Posted December 20, 2011 Author Share Posted December 20, 2011 well the only reason i grabbed the cherokee rear was for the perches being on top.. Link to comment Share on other sites More sharing options...
86customanche Posted December 20, 2011 Share Posted December 20, 2011 making the MJ sprung over will give you about 6" of lift with stock springs. should be the same width as the cherokee you pulled it from so the perches shouldn't have to be moved. Link to comment Share on other sites More sharing options...
Pete M Posted December 20, 2011 Share Posted December 20, 2011 a couple corrections. rules of thumb: 2.5L + 4spd manual = 3.55 gears 2.5L + 5spd manual = 4.10 gears You still have to move the spring perches on a cherokee axle no matter what you're doing with it. they are more outboard than comanche perches. Do not force it to work with the XJ perch location. you will eat you bushings in short order and then your axle will be off center. Link to comment Share on other sites More sharing options...
86customanche Posted December 20, 2011 Share Posted December 20, 2011 Mine was a 4 speed and it had to 4.10s. Was that an option that I guess I got lucky with? Link to comment Share on other sites More sharing options...
Pete M Posted December 20, 2011 Share Posted December 20, 2011 86 (which is the one I'm assuming you're referring too) is the exception to any of the gearing rules. almost seems like anything could have been had with anything else. you'd have to check to be sure what's underneath. also, it could have been replaced/upgraded in the last 25 years. I know I would have if I was stuck with 3.55 gears and a 2.5L. :D Link to comment Share on other sites More sharing options...
TylerJY Posted December 20, 2011 Share Posted December 20, 2011 making the MJ sprung over will give you about 6" of lift with stock springs. should be the same width as the cherokee you pulled it from so the perches shouldn't have to be moved. Nope, definitely not the same width dude. :smart: :no: Link to comment Share on other sites More sharing options...
thatjeepguy64 Posted December 20, 2011 Author Share Posted December 20, 2011 ok thanks for the information :cheers: ...ill hang on the 4.10 rear for something else and take a gander at what gear ratio my comanche is since its an 86 Link to comment Share on other sites More sharing options...
Pete M Posted December 20, 2011 Share Posted December 20, 2011 moving perches is easy. just get the welding done at your local muffler shop. :thumbsup: Link to comment Share on other sites More sharing options...
