Year 1990
Make Jeep
Model Comanche
Engine 4.0
Trans Automatic
Transfercase N/A
Build date:
Current Location: Calgary Ab. Picknpull
Status: Scrapyard
Notes: Anything that makes this comanche different from the rest.
Comanche bed liner. Blue exterior Gray interior Bench seat
I removed the cab head liner, rubber cab floor, fuel pump and visor's.
  • 7 years later...
*E1 Cloth Bench Seat
-SA Charcoal
125 Zone 25-Canada-Alberta
1AB Canada Dealer Retail
3N8 Drive Away Program Tracking
4CP Federal A/C Excise Tax
ADH Heavy Duty Electrical Group
ALA SE Decor Group
APA Monotone Paint
BA1 100 AMP ALTERNATOR
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHT Elec,Shift-on-the-Fly,P/Time T/Case
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAZ DO NOT USE - See JP, KA classes
JDB 180 KPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KWW T: BRILLIANT WHITE - NAMEPLATES - W
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
LMK Daytime Running Headlamps, High Beam
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF5 Fuel Tank - 23 Gallon
NHK Engine Block Heater
PQ9 DK BALTIC BLUE MET CC PRI PNT - HQ9
QQ9 DK BALTIC BLUE MET CC SEC PNT - HQ9
RA8 Delete Radio
SBA Power Rack and Pinion Steering
SCB Perforated Steering Whl w/Red Stitch
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TAA All Tires
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TPF P205/75R15 BSW All Season Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAC Build To Canada Mkt. Specifications
YGA Without Billable Fuel
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z58 Left Front Spring Group Viii
Z78 Right Front Spring Group VIII
Body Model Tl62
Build Date 10/12/89
  • 1 year later...
