mpace6a Posted December 16, 2011 Share Posted December 16, 2011 Anyone on here ever do, or know anyone whose done a 318 swap on their 'manche? I can pick one up for fairly cheap, and was wondering how much more difficult it would be than the 4.0? I have an '86 with the firewall that doesnt match up for the 4.0 btw, with a partially disassembled 2.8 in it atm. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted December 16, 2011 Share Posted December 16, 2011 There are a few on here doing that. Just go through the Projects section, and youll find some. Link to comment Share on other sites More sharing options...
shelbyluvv Posted December 16, 2011 Share Posted December 16, 2011 Is it going to be fuel injected? Nobody makes motor mounts. you are going to have to fab your own. The rad support is a special thing on the 86. You will have to figure out your own cooling system. There are three 5.2/5.9 MJ swaps that I know of on this board. Mine (Black Betty) thread below in my sig. Which is a 86. Terrawombat's and 360mjdude's, 86 as well. Link to comment Share on other sites More sharing options...
Exgrayxj Posted December 16, 2011 Share Posted December 16, 2011 I have wondered about this myself, and I am sure others know the answer to this. The frame rails on the early Grands are set up to have the same locating points for the suspension, and appear similar to the xj/mj. My question is how do those mounts work or appear to work for this swap? They must not work or the guys doing the swap wouldn't be going to the trouble make their own. :dunno: Link to comment Share on other sites More sharing options...
mpace6a Posted December 17, 2011 Author Share Posted December 17, 2011 hmm..well i was told if i do a 4.0 swap, that i would have to swap out the rad support and hood from an xj or mj with the 4.0, anyone know if this will clear for the 318? Link to comment Share on other sites More sharing options...
Exgrayxj Posted December 18, 2011 Share Posted December 18, 2011 I believe the reason for the core support swap is to allow for the different radiator mounting of the 4.0 radiator, due to engine length, not so sure about the hood? I think there are front crossmember problems also. My '89 XJ Wagoneer has a LT1 Camaro motor/trans in it, using a stock 4.0 position radiator, BUT, the LT1 doesn't have a belt driven water pump, so has a shorter front accessory drive. The length of the motor/pump may cause problems. There are those here who have dealt with this swap and a search might give you some clues as to what is needed. :dunno: Link to comment Share on other sites More sharing options...
