neohic Posted February 28, 2012 Share Posted February 28, 2012 Gonna need this thing for the fresh snow! Link to comment Share on other sites More sharing options...
Abyx Posted February 28, 2012 Share Posted February 28, 2012 Hey man good work on fixing your truck, I just wanted to point out that you said you 'made' a new clutch line? I wanted to warn you that there's a rubber section of that hose for a reason, if you have a straight piece of brake line, yeah it will work - but it will break at the worst possible time so be careful of that. The rubber section is to compensate for vibration and the shifting of the motor/trans. I'd get the replacement hose asap, Napa sells them for about 25$. Link to comment Share on other sites More sharing options...
xjrev10 Posted March 9, 2012 Author Share Posted March 9, 2012 Hey man good work on fixing your truck, I just wanted to point out that you said you 'made' a new clutch line? I wanted to warn you that there's a rubber section of that hose for a reason, if you have a straight piece of brake line, yeah it will work - but it will break at the worst possible time so be careful of that. The rubber section is to compensate for vibration and the shifting of the motor/trans. I'd get the replacement hose asap, Napa sells them for about 25$. Do you happen to have a part number? If the thing breaks, its never more then 100 feet from the garage so its not going to be a big deal. Thanks for the input, I will not be doing that to something that I drive and depend on thats for sure. Link to comment Share on other sites More sharing options...
