Darren Posted January 21, 2007 Posted January 21, 2007 Ok i don't know if this is a dumb question or not. I just bought 4.56 gears for my 30/44 and i need different carriers. does a locker run in place of a carrier? so should i just go that route? also how would lock-rite's do on the street?
DirtyComanche Posted January 21, 2007 Posted January 21, 2007 Well, a full carrier locker replaces the carrier (detroit locker/softlocker/no-slip and other similar items). But, 'lunch-box' lockers (lockrights, quik-locs, aussie lockes) don't replace the carrier, just the spyder gears. You can ask if a 'thick' gearset is avaliable for your application if you don't want to buy a new carrier or full locker. I'd buy a full locker and be done with it. Edit, you already bought the gears, so the thick option dun work.
Darren Posted January 21, 2007 Author Posted January 21, 2007 thank you. So where do i get a "full locker" for cheap?
CWLONGSHOT Posted January 21, 2007 Posted January 21, 2007 About any of them will run you 500 +. Also to back up a bit... There are "breaks" where a carrier makes a change in dimensions to coincide with gear ratios. On the D30 this is 3:73 up for one and 3:55 and down for the other. On the D44 its at 3:92 and up and 3:73 and down. This is where the thick set Dirty was referring to would come into play. Say you had 3:07 gears for your D30, and wanted 4:56. T think set of gears would allow your carrier to work with the 4:56 even though with a std set of gears it would only work with up to a 3:55 gear set. Get it? You can get the stock carriers of EBAY if you don't go the locker route. I WAS going to go with a Aussie locker myself. this is a "LUNCHBOX" locker. It is called this because it fits INSIDE a stock open carrier. it replaces the inner gears in the carrier creating a locker. Trouble is, they are out of stock and won't start getting them in until Feb and there is something like 2000 orders as of middle of last month!!! I decided to go with another ECTED. like I have in my TJ. This is a good price at 550 SHIPPED from 4wdwarehouse online. I happen to have a D44 carrier for 3:92 and up gears I bought on EBAY that I will not be needing. I'll sell to you for what I paid if you choose to go this route. There are other LUNCHBOX lockers you could go with if you choose this route. These style lockers generally run 250 - 300 bucks whale full case lockers START at 500 and go up from there. Good luck, CW
sinnaevd Posted January 21, 2007 Posted January 21, 2007 what is the difference between a full locker and a lunchbox?
pingpong Posted January 21, 2007 Posted January 21, 2007 Lunch box lockers just replace you speider gears, and do not require setting gears up. A full locker replaces the carrier and all and has to be setup like new gears, also they are 2to 3 times as expensive.
RandysMJ Posted January 21, 2007 Posted January 21, 2007 Well, a full carrier locker replaces the carrier (detroit locker/softlocker/no-slip and other similar items). But, 'lunch-box' lockers (lockrights, quik-locs, aussie lockes) don't replace the carrier, just the spyder gears. No-slip is a lunch box locker, not a full locker. I've always got my lockers from ebay.
DirtyComanche Posted January 21, 2007 Posted January 21, 2007 Well, a full carrier locker replaces the carrier (detroit locker/softlocker/no-slip and other similar items). But, 'lunch-box' lockers (lockrights, quik-locs, aussie lockes) don't replace the carrier, just the spyder gears. No-slip is a lunch box locker, not a full locker. I've always got my lockers from ebay. Really? Oh right. A detroit is a 'no-spin' in trachtech's books. Nobody sells it under that name anyways.
