Eagle Posted July 19, 2014 Share Posted July 19, 2014 Okay someone stated that the XJ Bushwacker flares won't fit an MJ. What about these Bushwackers I want to order them but I want to make sure they will work. These are not the same ones are they? Part #:[/size] [/size]10912-07[/size] http://www.bushwacker.com/search-results?field_make_model_year=55483&field_replacement_part=0 [/size] From the site: Fitment Note: Fits 2-door Sport Utility Models Only This says to me they are selling 2-door XJ flares for the MJ. Looks like they can work, but probably require some fitting and adaptation. Link to comment Share on other sites More sharing options...
Lowly Posted July 19, 2014 Share Posted July 19, 2014 Hmm not sure if it's worth 500 bucks if I am not sure if they fit. My biggest concern is I don't want them to cover up the fuel door. Link to comment Share on other sites More sharing options...
88ComancheMitch Posted July 19, 2014 Share Posted July 19, 2014 https://www.google.com/search?q=replacement+flares+2000+k2500&client=ms-android-virgin-us&espvd=1&source=univ&tbm=shop&sboxchip=Shopping&sa=X&ei=9Gq9U6edC8W-8gGr-IBo&ved=0CBwQsxg&biw=320&bih=460#spd=16811708114836151867 Under 60 bones a pop... Not bad when compared to other aftermarket flares. That's just for one though. Ebay has sets of 4 for around $100~ They even have a "Rivet style" Version too Link? I couldn't find them Link to comment Share on other sites More sharing options...
holeski Posted July 8, 2015 Share Posted July 8, 2015 There used to be 3 molds of the bushwackers. 2dr XJ, 4dr XJ and the MJ. The difference between the 2dr XJ and MJ rears where the MJ ones where open a little more length wise front to rear of the flair. They only make the 2 sets now for 4dr XJ and 2dr XJ/MJ. I haven't had a set of them in for years to tell which one they kept making. As the Notch Customs, they look great, but are poorly built and won't stay on if you rub them on something. The mounting bolts brake right off the fiberglass and there is now good way to fix them. They have poor customer service and absolutely no kind of warranty even if they show up damaged. Link to comment Share on other sites More sharing options...
