motorbikejedi Posted November 28, 2011 Share Posted November 28, 2011 I was wondering if anybody knows if a radiator from a 94 cherokee 4.0 will fit an 88 comanche with a 4.0? I am curious because I may be picking up this truck which needs a radiator and have a 94 cherokee for parts. Just curious, I am sure parts can be changed to get it to fit, but interested to know, Thanks. I looked up the parts at a part store site, they offer two different radiators for these, they are different but all the specs are the same. Thanks Kevin Link to comment Share on other sites More sharing options...
Pete M Posted November 28, 2011 Share Posted November 28, 2011 yes, they swap. and you'll gain a rad cap in the process. :thumbsup: you can also swap to the entire open system if you want. Link to comment Share on other sites More sharing options...
dfreeman616 Posted November 28, 2011 Share Posted November 28, 2011 the other thing to keep in mind is with the radiator cap on the 94 rad, you'll also have an overflow hose to deal with. Link to comment Share on other sites More sharing options...
mvusse Posted November 28, 2011 Share Posted November 28, 2011 Also, if your radiator has a temp sensor in the tank (driver side) for the auxiliary fan, the newer ones don't have a hole for it, also some have a spot in the casting that can be drilled out for one. Another solution for this is a HO thermostat housing that has the temp sensor. But physically it will fit. Link to comment Share on other sites More sharing options...
