guys there is a thing leeking oil on my mj lol like all of them lol but there is a peice comming off my block that turns up where you screw on the oil filter is leeking oil and i replace the o rings and well i just want to no if anyone has this prob and when they do to fix it or just to cope wit it
If you're talking about the oil filter mount, there are some O-rings that seal the mount to the block. I haven't done it yet (someday I'll get around to it), but I think it's just a matter of undoing a bolt and replacing the O-rings inside.
i did replace the o rings that that is the weird thing i went to the dealer and well there are 3 o rings and well i replaced them and it is still leaking lol i have no clue why they are not sealing right they seemed a little smalll but that is what the dealer gave me i might have to do that conversion if i can't figure it out now
ps where can i buy that conversion and how much is it
did you lightly coat the o-rings with oil before you reinstalled them?
Did you tighten the bolt to spec with a torque wrench?
Did you clean the mating surfaces?
I did this on my XJ right before I sold it. I got the three O-rings I needed from Carquest. I just took the deal in there and we found the ones that fit around each one. A total of $1.37 in all and my problems were solved!
