cody4359 Posted October 29, 2011 Share Posted October 29, 2011 I'm getting ready to start fabbing up a bumper in the future so ive been playing around with my welder. it's only a 110v, going to need to go to my works shop and use their millermatic when the time comes. but I'm getting to the point where I'm not embarrased to say i did that :) getting a portaband tomorrow, thatll get my small pieces cut, working on finding a milwaukee hog saw, or i might have to borrow works. drifted kinda far away in a few spots so it ugly, seemed like the gas was acting up too. thick metal for my little miller getting there cutoff and re-welded the end of my kevin offroad steering box brace (messed up from the factory) my weld, untouched up just painted their weld, holy BLOB. not too impressed Link to comment Share on other sites More sharing options...
Comanche County Posted October 29, 2011 Share Posted October 29, 2011 Looks good, any welder is only as good as his grinder. Link to comment Share on other sites More sharing options...
cody4359 Posted October 29, 2011 Author Share Posted October 29, 2011 thanks, andi hope you talking about gaps ;) Link to comment Share on other sites More sharing options...
Comanche County Posted October 29, 2011 Share Posted October 29, 2011 An old welder I once knew always said to me, "A welder is only as good as his grinder". I mean that the piece to be welded has to be ground down to bare metal and cleaned well (acetone, MEK or similar), otherwise the weld will be contaminated. Looks like you did that. I'm no CWI and can barely weld myself, yours looks better than mine. If I had an extra 220 hook up, I'd be in possession of bigger welder, for now I have a little jobber too. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted October 29, 2011 Share Posted October 29, 2011 turn down the wire speed a tiny bit, or speed up moving your hand a bit. it's pooling up a bit more than necessary for a single pass weld. aside from that, and a couple small gaps where you stopped then continued, it looks very good. Link to comment Share on other sites More sharing options...
cody4359 Posted October 29, 2011 Author Share Posted October 29, 2011 one of these years I'm going to tear down this garage that is more like a wood shed and build a real shop. ill have 220v power, concrete floor and a roof that won't leak, then ill get set up for making things nice. it would definatley help the motovation. i have the temp all the way up (10) and the wire speed is at 40 (less than half) any less and it just makes a bright light then clogs the tip. ive recently started moving faster and thats helped alot, might have to try going faster yet and see what happens. here in the next month or 2 work is going to be giving me alot of welding project (mostly stick) and my 2 bosses are badass welders so ill be getting all tuned up Link to comment Share on other sites More sharing options...
Backdraft Posted October 29, 2011 Share Posted October 29, 2011 They look way better than my welds. And I'm driving around on mine! Link to comment Share on other sites More sharing options...
xjrev10 Posted October 29, 2011 Share Posted October 29, 2011 Looks good, any welder is only as good as his grinder. Or he uses the welder to clean up his weld :doh: Link to comment Share on other sites More sharing options...
cody4359 Posted December 22, 2011 Author Share Posted December 22, 2011 getting a little better, also alot nicer machine and 220v and after and hr of stick welding with 7018 today they don't look horrible. now starting and stopping is the next skill i need to work on Link to comment Share on other sites More sharing options...
Lee21490 Posted December 22, 2011 Share Posted December 22, 2011 I need to learn how to weld one of these days. But for now, I just have a friend of mine do it for me Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 22, 2011 Share Posted December 22, 2011 those welds look very nice. I can't really tell from the pics, but are you sure you got the cast hot enough to penetrate? I'm not asking to be mean, or critique you at all, just asking because it really is very hard for even a professional welder to get good penetration without pre-heating the cast. Link to comment Share on other sites More sharing options...
cody4359 Posted December 22, 2011 Author Share Posted December 22, 2011 unsure of how hot it should have been. i tacked it then heated it hot to the touch with a torch, then started welding around not letting it get too hot. i was more worried about warping it and didnt really think of it being cast :dunce: i did atleast cover it with a fire blanket and let it cool Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 22, 2011 Share Posted December 22, 2011 unsure of how hot it should have been. i tacked it then heated it hot to the touch with a torch, then started welding around not letting it get too hot. i was more worried about warping it and didnt really think of it being cast :dunce: i did atleast cover it with a fire blanket and let it cool generally you heat it to a low red hot before you weld to it, but you should be just fine if you heated it hot to the touch using a torch. the real key when welding to cast is that you concentrate the weld on the cast (getting it hot on the cast) and pool it over to the steel. two different metals with two very different "melting points". I wouldn't worry about it too much. just check here and there to make sure that the welds are not cracking...if they do, then you can simply clean up and re-weld. not a huge deal, and you certainly can't wreck the inner C by not getting it hot enough. better to play it safe right now while you improve your welding technique (which is pretty damn good so far) Link to comment Share on other sites More sharing options...
cody4359 Posted December 22, 2011 Author Share Posted December 22, 2011 thanks for the advice/ complements. looking for a upper control arm mount lastnight i read something about getting it redhot, just seems like that would warp the crap outta it (the c's) and cause pre-mature balljoint failure down the road :hmm: either way i have new axles going in once H3RESQ commits to the sale.. :D Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 22, 2011 Share Posted December 22, 2011 thanks for the advice/ complements. looking for a upper control arm mount lastnight i read something about getting it redhot, just seems like that would warp the crap outta it (the c's) and cause pre-mature balljoint failure down the road :hmm: either way i have new axles going in once H3RESQ commits to the sale.. :D that's a proper theory on getting all of it red hot. but you're only heating up the sides...the area directly where you're welding. Link to comment Share on other sites More sharing options...
