RockMJ Posted October 15, 2011 Share Posted October 15, 2011 Hey guys, my MJ is in need of the drivers side floor being replaced and I need to find someone with a welder living in Florida. I live in New Port Richey and sadly, my MJ isnt on the road right now which makes things increasingly difficult. So essentially, I'm seeing if anyone is local to me who would be willing to give me a hand? Name a price and well get it done. Thanks guys, RockMJ Link to comment Share on other sites More sharing options...
RockMJ Posted October 16, 2011 Author Share Posted October 16, 2011 Anyone? RockMJ Link to comment Share on other sites More sharing options...
btm24 Posted October 17, 2011 Share Posted October 17, 2011 Sorry I don't know any body near you that could help :dunno: and I don't know how to :( Brandon Link to comment Share on other sites More sharing options...
Comanche County Posted October 17, 2011 Share Posted October 17, 2011 What though is the problem? I'm assuming the hinges have broken off at the factory weld? if so, welding may not be necessary. There's a way to fix it by bolting plates behind the pillar sheet metal which acts as a brace and bolting the hinge back on. viewtopic.php?f=2&t=21621&hilit=door+hinge+repair viewtopic.php?f=7&t=17699&hilit=Megan+Joy Link to comment Share on other sites More sharing options...
RockMJ Posted October 17, 2011 Author Share Posted October 17, 2011 No, my doors are in great shape its just the drivers side floor needs a repair. I would like to weld in a new floor pan but if I have to do it without I can as well. I would just like to do it "right" RockMJ Link to comment Share on other sites More sharing options...
Comanche County Posted October 17, 2011 Share Posted October 17, 2011 Sorry, I read "door" not floor. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted October 18, 2011 Share Posted October 18, 2011 as a quick fix you can use a rivets to attach the sheet metal and J B quick weld to seal it, it won't look nice, but it will get the job done, later on it can be removed and welded on.. where you going to use carpet? if so then you should not notice it at all edit: you can also rhino line it, that will seal the top of it , i would run a bead of quick weld around the corner of the patch metal for a seal then come back around the corners of it inside and under the cab, top it off with rhino liner. Link to comment Share on other sites More sharing options...
RockMJ Posted October 20, 2011 Author Share Posted October 20, 2011 I will be utilizing a POR-15 floor pan kit that I bought. Ive always had great results with their stuff so worst comes to worst I can put some plates on top with rivets, seam seal it, and bed liner over it when I'm done. And some times welding it makes it look worse. Ive seen some scary blobs over the years lol RockMJ Link to comment Share on other sites More sharing options...
87Chief Posted October 21, 2011 Share Posted October 21, 2011 Get one of those cheap mig welders from harbor frieght, I think they are $89.99 with the coupon. I've looked on youtube for reviews of it... Seems pretty good for small stuff Link to comment Share on other sites More sharing options...
RockMJ Posted October 21, 2011 Author Share Posted October 21, 2011 Yeah, I just need to do some minor sheet metal repair is all. Not looking for OEM quality just good enough to make it solid again. Ill figure something out but thanks for the input guys RockMJ Link to comment Share on other sites More sharing options...
