RockMJ Posted September 5, 2011 Share Posted September 5, 2011 Hey guys, I just replaced my 5 amp wiper relay circuit fuse and the wipers now work! However, I have no intermittent wipers or low speed, only high. Also, my wipers when I turn them off won't return to the bottom of the windshield they just stay wherever they were. I know this isnt normal so is there a relay that may be bad or is it the wiper motor? Thanks RockMJ Link to comment Share on other sites More sharing options...
KYMJ Posted September 5, 2011 Share Posted September 5, 2011 The wiper "box" that velcros to the lower dash panel needs replacing. Look for a gray box. Find one at the JY. I had to replace it on both my Comanches due to the same symptoms. Link to comment Share on other sites More sharing options...
RockMJ Posted September 5, 2011 Author Share Posted September 5, 2011 Alright thanks for the input! Are these the same for XJ's as well? RockMJ Link to comment Share on other sites More sharing options...
MJRemi Posted September 5, 2011 Share Posted September 5, 2011 Check the intermittent wiper box velcroed to the inside lower dash panel. Unplug both ends and plug the ends into each other. Your wipers should work at slow and high speed. These boxes are easy to come by at junkyards so I would get a couple spares or see if any members have one that they can sell cheap. The bushings on the wiper motor assembly tend to wear out and can be replaced fairly easily. Look through DIY section for wiper motor replacement and one for wiper bushings replacement. Both posts are very good at walking you through the job. That will solve your lazy wiper issue. Link to comment Share on other sites More sharing options...
RockMJ Posted September 5, 2011 Author Share Posted September 5, 2011 So if I plug them into each other can I leave it like that and bypass the intermittent wipers for the time being? I'm assuming that I can but just would like to know ahead of time RockMJ Link to comment Share on other sites More sharing options...
ParadiseMJ Posted September 5, 2011 Share Posted September 5, 2011 Yes. Link to comment Share on other sites More sharing options...
MJRemi Posted September 5, 2011 Share Posted September 5, 2011 Alright thanks for the input! Are these the same for XJ's as well? RockMJ Yes. Link to comment Share on other sites More sharing options...
RockMJ Posted September 6, 2011 Author Share Posted September 6, 2011 10-4 Thanks guys! RockMJ Link to comment Share on other sites More sharing options...
