BLHTAZ Posted January 7, 2007 Author Share Posted January 7, 2007 I got these... :D He only lives about 3 hours south of me, so I should have them in just a couple days. Link to comment Share on other sites More sharing options...
Rokhound Posted January 7, 2007 Share Posted January 7, 2007 let use no if they work becouse i was looking at the top ones and like you said there is a diff between the 2 Link to comment Share on other sites More sharing options...
BLHTAZ Posted January 7, 2007 Author Share Posted January 7, 2007 I will be on here with results as soon as I have them. I am not looking for performance gains...I have a leaking issue on one injector and a bit of a rough idle problem as well, so I hope this cures both. Link to comment Share on other sites More sharing options...
Bounty Hunter Posted January 7, 2007 Share Posted January 7, 2007 If you want to make sure your injectors are working properly: http://www.cruzinperformance.com/fuelinj.html Link to comment Share on other sites More sharing options...
sinnaevd Posted January 8, 2007 Share Posted January 8, 2007 make sure u check for fuel difference lol i desperately want to know the answer to that question Link to comment Share on other sites More sharing options...
BLHTAZ Posted January 13, 2007 Author Share Posted January 13, 2007 They are installed. I will let you know what the difference is in MPG as soon as I can. We don't drive it a lot, but I will try to drive it more this week as we will be gone on vacation for 10 days starting on 1/20. The MPG before the swap was 15. It definitely cured the rough idle problem. This thing purrs like a kitten now. Since it doesn't have a tach, I had to push on the gas peddle a couple times while sitting at a light to see if it was still running 8) :D . A word of advice to anyone doing the swap...BE SURE TO LUBE THE NEW O-RINGS with just a little bit of grease before trying to install the injectors. They WILL rip :oops: if you push too hard and don't have them lined up perfectly straight. It makes a lot of smoke when raw gas is running down over the exhaust manifold :eek: . Link to comment Share on other sites More sharing options...
ejndssn Posted January 13, 2007 Share Posted January 13, 2007 :cheers: for having them installed and what a great deal you got for them enjoy your vacation and we will be waiting on the results i will be doing the same on the 89 and 96 XJ as for the MJ she'll have to keep what she got since she is a 4.6l Link to comment Share on other sites More sharing options...
