rcr1971 Posted August 8, 2011 Share Posted August 8, 2011 I just recently bought a 1988 Comanche Pioneer and am experiencing what I believe to be the infamous death wobble! When I reach aprox 50-55mph the entire front end shakes uncontrollably and I have to come to a complete stop for it to go away. I just got stock Jeep rims to see if that made a difference and it seems to have helped a very small amount. I have researched this topic and see that I am not the only one who deals with this and am confused where to start since many people fixed their issue by replacing not the same parts as others. If anyone could be of any help, it would be greatly appreciated. Ive been told to start with either the tie rod or wheel bearings? Link to comment Share on other sites More sharing options...
banshee Posted August 8, 2011 Share Posted August 8, 2011 Check; Tie rod ends and/or ball joints, most likely one or more have massive play, if not have the alignment chacked cam/caster could be that simple… B… Mine was two tierod ends and the cam/caster was off badly from hitting ??? good luck Link to comment Share on other sites More sharing options...
kar120c Posted August 8, 2011 Share Posted August 8, 2011 If your shaking is brought on every time between 50-55 I'd say tires are probably extrememly out of balance or shot. If the tires are new or you know them to be balanced it is probably ball joints or tie rods like banshee suggested. I'd also take a look at your bushings on the lower and upper control arms. My death wobble was from worn out lower control arm bushings. Link to comment Share on other sites More sharing options...
shawn Posted August 8, 2011 Share Posted August 8, 2011 :agree: i'd definitely start with having them balanced. thats exactly how mine behaved, and then at least you will know. Link to comment Share on other sites More sharing options...
flint54 Posted August 8, 2011 Share Posted August 8, 2011 Also check the track bar and mount. Have someone else sit in the truck and crank the wheel both ways vigorously while you feel each and every connection for freeplay. If your tires are more than a few years old they can have internal degradation in spite of the tread condition. IF tires are good, have them road force balanced for best result. Link to comment Share on other sites More sharing options...
Vintage Posted August 9, 2011 Share Posted August 9, 2011 Also check the track bar and mount. Have someone else sit in the truck andcrank the wheel both ways vigorously while you feel each and every connection for freeplay. A balancing and a new track bar did it for me. Exact same symptoms. Link to comment Share on other sites More sharing options...
Car RamRod Posted August 9, 2011 Share Posted August 9, 2011 I had a bad track bar as well. +1 to visually inspecting while someone turns the wheel. Link to comment Share on other sites More sharing options...
Comanche County Posted August 10, 2011 Share Posted August 10, 2011 Also check the track bar and mount. Have someone else sit in the truck andcrank the wheel both ways vigorously while you feel each and every connection for freeplay. A balancing and a new track bar did it for me. Exact same symptoms. Roger that, do as prescribed above. If you have a mild lift or a stock set up, ensure all joints are tight. I had several different mix and match lifts on the truck and had several instances of death wobble. Each time was simply an alignment problem or worn or loose part. Link to comment Share on other sites More sharing options...
Eagle Posted August 10, 2011 Share Posted August 10, 2011 Tire balance. TIRE BALANCE TIRE BALANCE TIRE BALANCE Link to comment Share on other sites More sharing options...
