For the unit bearing? If so I have couple laying in the scrap pile there off a 99 XJ I would think there the same. If I can get them out without to much work you can have them for shipping.
You might want to specify which U-joint size you need.
Also... 3?
I'm not sure didn't know that would matter? It's just a regular u joint I guess, the front axle is out of a 86 XJ if that matters.
And yeah the front end came with only one hub installed when I bought it and the other one antidisestablishmentarianism MIA. So because of that I only have 3 from that one side.
Here's a pic office I'm talking about kinda... IRS the best thing I could find online but if needed I can take a pic of one.
It's a 12 point, about idk 4" long. If you hve 3 or so that would be great, thank you :)
Brandon
Oh, you want the BOLT. They're not studs. The way you initially asked, I read as you wanted the stub shaft that attaches to the U-joint and goes inside the bearing.
Ok now we know what you need however those I do not have. I bought mine from daveysjeeps.com they were like 1.00 each. It was the only place other than the dealer I could find them.
Oh well alright sorry for calling it the wrong thing, some one at the junk yard said that they were studs not bolts. I didn't think that sounded right. I'll check out that web sight thanks :)
Brandon
