btm24 Posted August 7, 2011 Posted August 7, 2011 I need 3 4wd front axle hub studs. Please pm me if you have any Brandon
Geonovast Posted August 7, 2011 Posted August 7, 2011 You might want to specify which U-joint size you need. Also... 3?
sinkrun Posted August 8, 2011 Posted August 8, 2011 For the unit bearing? If so I have couple laying in the scrap pile there off a 99 XJ I would think there the same. If I can get them out without to much work you can have them for shipping.
btm24 Posted August 8, 2011 Author Posted August 8, 2011 You might want to specify which U-joint size you need. Also... 3? I'm not sure didn't know that would matter? It's just a regular u joint I guess, the front axle is out of a 86 XJ if that matters. And yeah the front end came with only one hub installed when I bought it and the other one antidisestablishmentarianism MIA. So because of that I only have 3 from that one side. Here's a pic office I'm talking about kinda... IRS the best thing I could find online but if needed I can take a pic of one. It's a 12 point, about idk 4" long. If you hve 3 or so that would be great, thank you :) Brandon
Geonovast Posted August 8, 2011 Posted August 8, 2011 Oh, you want the BOLT. They're not studs. The way you initially asked, I read as you wanted the stub shaft that attaches to the U-joint and goes inside the bearing.
sinkrun Posted August 8, 2011 Posted August 8, 2011 Ok now we know what you need however those I do not have. I bought mine from daveysjeeps.com they were like 1.00 each. It was the only place other than the dealer I could find them.
btm24 Posted August 9, 2011 Author Posted August 9, 2011 Oh well alright sorry for calling it the wrong thing, some one at the junk yard said that they were studs not bolts. I didn't think that sounded right. I'll check out that web sight thanks :) Brandon
500 MJ Posted August 15, 2011 Posted August 15, 2011 If daveysjeep does not have these, I do. Let me know if you need them.
btm24 Posted August 15, 2011 Author Posted August 15, 2011 I got them in the mail yesterday $15 bucks for 6 :ack: but sits done :) thank you Brandon
