any one know the factory wheel base measurements for long and short beds? i need to find out if my parts truck is a long bed or not, i got 113in from center of hub to center of hub for my 87 short bed. also how do i tell what options it had factory from the vin number(ie metric ton package)
You can look at the leaves for the metric tonn I think they had more or thicker ones. Also the rear axle should be a AMC 20 or a D44 if it is metric ton.
Cole
The shape of it If its got alot of flat sides then its prob a 44 if its a basketball its a 20 if its niether of those its a 35. Thers pics somewhere on here.
Cole
113 is a short bed and that won't be a Metric Ton. There's always the possibility of a different axle being swapped in though.
SWB = 113
LWB= 120
1986 models w/metric ton where AMC20's all other years where D44's.
D44 In a MJ:
Image Not Found
Image Not Found
D35 in a MJ:
AMC 20 in a MJ:
Cannot find the pic I hijacked from Pete...maybe he can throw one up for you to see....
CW
kool thx for the info guys, i measuer wheel base it is a shortbed, so from what ive read, tehy didnt make short bed metric ton mjs, correct?
Corect but it still could have a 44 as we have found out over the last few months there are more the a couple I know of thats had them. CHeck those pics in the link I posted and see what you got. Also The guy in need of a bed is interested since it is a SWB. Ill pm him or you can he posted in the classifieds in that thread I started about it.
Cole
naw, the frames fine,. it's just everything that wasn't painted.
most everything up this way looks like that underneath.
People in the rust belt love 3 things:
PB Blaster
Torches
Air Tools
They're needed for most everything that goes on under my truck, and everything get's put back together with neverseize.
i HATE rust. :fool: the manufactorers for poorly designing wiper cowls on fords :headpop: sorry had to vent haha
